Another brent STSGTO run
Old Jan 11, 2005 | 02:02 PM
PurEvl's Avatar
Default Another brent STSGTO run
this one has the burnout and the sound is better synced
STS@TRACK
Old Jan 11, 2005 | 02:06 PM
F8L Z71's Avatar
12 Second Truck Club
Nobody would ever expect it to be that fast if it pulled up to you at a light. LOL
Old Jan 11, 2005 | 02:12 PM
NA$TY-TA's Avatar
bad ***..... i love the Turbo sound..... great run for a heavy *** car.... what did it wieght again?? Dyno?? When you going to run yours at the track?? I know your not in any big hurry.
Kyle
Old Jan 11, 2005 | 02:13 PM
SPANKY LS1's Avatar
Sounds and runs good but that thing has zero ground clearance. Is this a result of being an early GTO kit? Also, do the F-body STS kits hang that low also, I've never seen one from far back?
Shawn
Old Jan 11, 2005 | 02:26 PM
NOSjohn's Avatar
Restricted User
nice run...i wonder what type of boost he's holding at the line?
Old Jan 11, 2005 | 03:09 PM
PurEvl's Avatar
Shawn
huh? Its tucked way up compared to an fbody kit and I never have scraped a thing? I dont think you can even see it on the gto
Old Jan 11, 2005 | 03:10 PM
PurEvl's Avatar
Kyle
like 490 hp 4000 pounds. No track open for me to run, and when there is the ls2 402 and afr heads will be in so should be interesting to say the least
Old Jan 11, 2005 | 08:30 PM
brent eb02's Avatar
hey thanks for posting...............
thanks for the props guys
Old Jan 11, 2005 | 08:34 PM
NA$TY-TA's Avatar
Thatll be bad *** did Don buils the new LS2 402??? Is the motor done?? You going to run the same turbo.......??
What track were these runs made at??
Kyle
Old Jan 11, 2005 | 09:23 PM
Slowhawk's Avatar
LS1Tech Sponsor
Kyle
The plan is to make Mike's car just plain stupid on the street.Probly 800+hp and 750+tq on pump gas.
Old Jan 11, 2005 | 10:07 PM
Drewman's Avatar
Still plan an STS setup with the 402?
New (larger) turbo?
More details please.
Old Jan 11, 2005 | 10:27 PM
NA$TY-TA's Avatar
You going to try and do it on a stock PCM also??? If not what??
Kyle
Old Jan 11, 2005 | 11:30 PM
Wicked_Hugger99's Avatar
sweeeeeeet
Old Jan 11, 2005 | 11:34 PM
Jammer's Avatar
Old Jan 12, 2005 | 12:39 AM
VaNDaL*SS*'s Avatar
does that GTO have any kind of drivetrain upgrades? im assuming that was on drag radials or something right?
Old Jan 12, 2005 | 07:12 AM
Slowhawk's Avatar
LS1Tech Sponsor
Kyle
STS Turbo-we will try the T70 first.Stock PCM.So far I haven't seen a reason not to use the stock PCM.Maxing the mass air is not a big deal since we max it already at 4000rpm and never have fueling issue's.
