Belt Rubbing From Hell!!!!!
Old Jan 16, 2005 | 08:49 AM
osuhunter07's Avatar
Default Belt Rubbing From Hell!!!!!
AHHHHHHH!!!!! I AM GONNA SHOOT MYSELF. The 4.25 pulley and all if it's hugeness some how somewhere the belt rubs. IT ATE ANOTHER BELT!!! another 30 down the drain so now i need to find out where it rubs.... AGAIN and do the whole tensioner thing again. THIS SUCKS~!!!!! just venting
Old Jan 16, 2005 | 10:28 AM
NA$TY-TA's Avatar
Is the support that SDCE sent with it on or does it not fit with the 4.25" pulley??? I forgot to put it on mine and the bracket was flexing and eating up the belt....... not bad enough to ruin it but it was eating it ...... the blower chattered also..... put the other bracket on that attaches to the oil pan and it was all good...... didnt you say scot was going to make u a different bracket or something.......
Let us know......
Kyle
Old Jan 16, 2005 | 11:10 AM
Got Me SOM's Avatar
welcome to ATI hell
Old Jan 16, 2005 | 02:54 PM
No i dont have the support bracket on. I hope that is the only problem.
Old Jan 16, 2005 | 03:15 PM
o yeah what happens is that it rips off the inner rib of the belt. from the drivers fender. it is the rib on the left. I have 2 7 rib belts now if any one needs one.
Old Jan 16, 2005 | 07:41 PM
Ponyhntr's Avatar
My guess is that there is an alignment problem...or the bracket is flexing.
Old Jan 16, 2005 | 08:15 PM
yeah i have to check both this teim really carefully, this is starting to suck a lot, But see this time I lost one of the washers for the outrig thing on the idler pulley so it was closer and more of the belt was to ****, sooo i think i need to add 2 and it should be fine. cause one it cracked less so 2 washers more should be good than right???
Old Jan 16, 2005 | 10:26 PM
Caveman's Avatar
10 & 11 Second Club
These belt problems are why I went with a Vortech Ttrim. Hope you get it figured out.
Old Jan 18, 2005 | 12:17 AM
hmmm so i thought it could be allignment. So i added another washer to the top left and now the belt jumped over towards the engine 2 ribs. So i guess that moved to far. GAYYYYYYYYYYY
Old Jan 18, 2005 | 12:39 AM
BIGBOS's Avatar
Its probably flexing.....get that support on
Old Jan 18, 2005 | 10:15 AM
damn still not here. I gotta make sure they sent it now. Thanks everyone
Old Jan 18, 2005 | 04:42 PM
frcefed98's Avatar
are you running different washers on each standoff??? Your last statement is throwing me, you said you added one to the top left? I think it should be an even amount of spacers per standoff.
Old Jan 18, 2005 | 09:25 PM
what is the easiest way to check allighnment?
Old Jan 18, 2005 | 09:36 PM
Avoided Z28's Avatar
belt problem sucks ............. try chucking 2 $130 cog belts on halloween at 41
Old Jan 18, 2005 | 10:08 PM
NA$TY-TA's Avatar
Straight edge.... have Scott or Wendy send you one when they send you the new bracket for the 4.25" pulley.
Kyle
Old Jan 18, 2005 | 11:30 PM
she said she was gonna ship out the new bracket last wensday but still not here
Old Jan 19, 2005 | 12:20 AM
blazin's Avatar
I had troubles eating the outside of my belts. I think there was a small peice of the belt hitting on the old fan motor. Don't feel bad my belts are 75 bucks each.
Old Jan 19, 2005 | 01:55 AM
BIGBOS's Avatar
I went through the COG garbage......I was getting belts for $30
Old Jan 19, 2005 | 09:15 AM
SDCE's Avatar
Hi Nick,
It did ship already...you should see it any day??
I'll pm you the track #
It does sound like something's not quite lined up...let's walk thru it and get her fixed. Get that brace on there, and put the correct washers on there...if you need us to send you more shims, let me know. Give me a call and we'll talk about it...
wendy
Old Jan 19, 2005 | 10:25 AM
NA$TY-TA's Avatar
Originally Posted by SDCE
Hi Nick,
wendy
See now thats customer Service.....
Kyle
