PWM Boost Valve
Old Jan 25, 2005 | 06:26 PM
Green Thunder's Avatar
Default PWM Boost Valve
Anyone running a pulse type boost valve? Big Stuff 3 has a provision to control one and was wondering if anyone is doing it and if so what brand are you using?
Thanks,
P.S. I do know the Buick Grand Nationals had them stock.. But I believe I will need a bigger 1...
Old Jan 25, 2005 | 06:28 PM
NA$TY-TA's Avatar
hmmmmmm this is news to me what all does it do and how is it better to allow BS3 to work it...... im going with BS3 also..........
Kyle
Old Jan 25, 2005 | 08:33 PM
MIGHTYMOUSE's Avatar
'pulse width modulated' i believe
my e-boost has one allready.. dont know if i will get rid of the e boost and use the bs3 function or not but you could see what turbosmart wants for theirs.
in reply to the first post.. i dont know that there is a size range for these valves.. one that fits a 1/8" npt hose barb should work for any bost application
Old Jan 25, 2005 | 10:41 PM
Pulse width modulated is correct...
Mighty Mouse are you using all aftermarket gauges or did you "piggy back" to the factory gauges? Cant see the real benifit of giving up your e-boost after looking hard at the software, but im not up and running yet, should know more by this time next week.. How long have you been running BS3?
Kyle: From what I can tell it will work like a E boost controller would, but from your laptop.. Are you going to aftermarket gauges on yours? How long are you going to be down with the new retrofit? Understand your getting pretty wild this time around..
Old Jan 26, 2005 | 12:21 PM
i am not running it yet, its in my floor. but i have read all 130 pages of instructions
i have a separate coolant temp sensor for that, everything else as far as instrumentation was left the way it is and is functional WITH THE FACTORY PCM IN THE CAR STILL
if you share the signal of the crank sensor, your stock tach ''should'' work to but i have not tried this on my bs3 to confirm yet.
Old Jan 26, 2005 | 01:09 PM
I am planning to leave the stock PCM, and actually use it for trans control w/ hp tuners.. Did you buy the trans control? I am guessing you probably are not using an electronic trans anyway, so probably just answered my own question.. I am running a 4L80E and am contemplating adding thier (BS3's) trans control.. But I am definately running stock gauges..
When do you plan to install yours?
I ordered a couple of Grand National Boost "regulators" they are cheap from GM so we will se how they work out..
Did you figure out how the Knock sensors work out? I didnt think it would have Knock Sensor capability, but noticed in the software it had parameters for it, however the wiring loom doesnt.. Any Ideas there?
Thanks
Old Jan 26, 2005 | 02:41 PM
NA$TY-TA's Avatar
So what your saying is you can control your normal wastegate by using BS3 and your laptop?? Does it work if your laptop is not in the car?? I was wondering for my base settings of 8-10 psi for street use.
I am going all aftermarket gauges.
Autometer 5" tach up top near my A-pillar
Autometer 5" Speedo in dash
Autometer 2 5/8" Oil pressure
Autometer 2 5/8" Engine Temp
Autometer 2 5/8" Fuel level
Autometer 2 5/8" Voltage
All 5 of those gauges will be in the dash and my 2 5/8 boost and EGT will be in my center A/C Vents.......
All out this time.... T-88, swapping to a 6 speed becaus ei drive it to much and BS3 to control the 800rwhp we are shooting for.
If ya can can you PM me a article if there is any on how this works???
Thanks
Kyle
Old Jan 26, 2005 | 03:59 PM
Kyle:
PM sent
Old Jan 26, 2005 | 04:03 PM
i'm installing mine as soon as the weater permits.. i have a manual transmission. my stock computer still controls my reverse lockout (if anything)
there is no knock control for bs3 ls1 versions at this time.. i removed my knock sensors and the wire harness
hey you make me a complete drop in autometer dash like that and i'll buy it from you.
Old Jan 26, 2005 | 04:41 PM
there is no knock control for bs3 ls1 versions at this time.. i removed my knock sensors and the wire harness .
Thanks
Yeah Kyle Ill take one also! Theres your million $ Idea!
BTW: Mines a truck!
Old Jan 26, 2005 | 06:51 PM
NA$TY-TA's Avatar
Thanks
BTW: Mines a truck!
Thanks for the PM.... i skimmed it... ill read it very slow here ina bit... is that the owners manual?? If so got a link for it????
The dash i am going to do will look a little like this....
I havent decided yet if the Tach will go in like that or stay up top.... but all the other gauges will go in there....... i might do some Fiberglassing if i feel froggy then texture it and paint it the same color as the car.......
Kyle
Old Jan 26, 2005 | 07:00 PM
Dash looks sweet! ...
Old Jan 26, 2005 | 07:03 PM
NA$TY-TA's Avatar
Heres a few more from other angles
i guess i really didnt hijack this thread since its only the three of us posting and we all like what im talking about anyways.. ha ha
Kyle
Old Jan 26, 2005 | 08:25 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Where have I seen that dash before???? Kyle is that in your car??
Old Jan 26, 2005 | 08:27 PM
NA$TY-TA's Avatar
shut up............... maybe cause you can see that dash everyday................................... u still at work..................
Kyle
Old Jan 27, 2005 | 12:30 PM
red ws6 99's Avatar
Thanks,
You can still buy the Grand National solenoids for $16 new. Since your just bleeding the boost signal to atmosphere you really don't want a large valve. Of course this is going to make the spool a little slugish.
Gary
Old Jan 27, 2005 | 01:24 PM
Gary
Thanks Gary!
I have two sitting on my desk right now that I am going to give a try!
