How much boost?
Old Feb 11, 2005 | 01:44 PM
SR-71 SS's Avatar
Default How much boost?
How much boost can be safely put on the LS1 346 aluminum block with the stock crank assuming 9:1 compression?
Old Feb 11, 2005 | 01:48 PM
Zombie's Avatar
it's a tough question to answer. It depends mostly on the tune and octane of gas you are willing to run. Boost is also a horrible way to measure. It's nothing more than a measure of restriction.
I've seen people blow up cars on 5 psi and other live long lives on 10+ psi with stock motors.
Old Feb 11, 2005 | 02:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I believe Harlan is/was more like 8.75:1 but I'm sure he's hit like 23-24psi thru his.
I've gone 21psi with my 8:1 motor.
Old Feb 11, 2005 | 05:05 PM
SR-71 SS's Avatar
Thanks, reason for asking is I talked to the guy I am gonna have tune my engine for me and he told me that after 12 pounds the bearing start to walk and the block gets destroyed, I thought I would get a few second opinions from the guys who have already been there and done that
Old Feb 11, 2005 | 05:33 PM
ESR's Avatar
ESR
LS1TECH Sponsor
pushing about 15 or so and Im fine 8.97 to1 I think its more of a fueling question and timing not boost
Old Feb 11, 2005 | 05:34 PM
MelloYellow's Avatar
Where do these people come from?
Old Feb 11, 2005 | 06:33 PM
y2khawk's Avatar
closer to 30
Zombie's Avatar
I would love to know. Some guy locally here was telling another member that a 98 LS1 block is not worth building and to get a newer year block.
The amount of misinformation regarding cars is just unbelievable.
Old Feb 12, 2005 | 09:31 AM
427's Avatar
427
I agree. I would not use a early aluminum block for high output engine. On sustained high power level gen 3 engines, I have also noted main bearing cap walk.
I'm from Michigan....lol
Kurt
