1st Dyno - APE 370ci, Incon Twin Turbo
I didn't really want to push it last nite, being I haven't had it for a year I want to enjoy driving it for a while before I push the envelope.
Bottom line is 538rwhp, 586rwtq. This is on 91 octane, no alky on this setup, and just a hair under 10 pounds of boost. I'm going to list the differences between the old setup and the new, then post up dyno sheets. I'm not happy with these #'s, but there are a couple of reasons.
Old Setup
Stock block, 918 springs
Alky injection ( 15gph )
12psi boost
42lb injectors
New Setup
370ci iron block, 8.7:1 CR
222/218 563/563 114LSA
TEA 6.0L unported, o-ringed, 2.02/1.60 valves ( not positive on intake, what's stock? )
NO alky injection
10psi boost
60lb injectors
Here are the dyno sheets:
Old:
New:
The as you can see, I'm making a LOT less torque around 2500 than I was on the last combo, partially due to the 8.7:1 CR. Not real happy about that. BUT I think my other MAIN problem is the passenger turbo, you've probably seen my other post.
I've got oil leaking from the turbo, and it's making it's way into the host leading to the intercooler ( not a lot ), as well as into the exhaust, as within 30 seconds of a cold ( several hours ) startup it blows blue-grey smoke, but only for about 10 minutes, then it's gone. But on the dyno I noticed the boost coming up really slow, and they should spool even quicker on this bigger motor.
Sooo, it appears that the turbo is not working anymore. I don't know if it has bad seals, or it's not getting scavenged properly, or what. If I assume it's just the seals and fix it, this may happen again. Bottom line is the turbo is full of oil for whatever reason. Got the car up on ramps ( back end of car on ground ) and disconnected the oil feed line for that turbo from the distribution block by the oil filter. Nothing came out, so it appears the checkvalve is functioning properly, unless the car needs to be level for it to leak.
Need help!!!!
- Dug
Old Setup
12psi boost
42lb injectors
New Setup
NO alky injection
10psi boost
60lb injectors
Old:
New:
Need help!!!!
- Dug
Trust me, you didn't lose over 150 ft-lbs of torque at 2500 RPM's because you went down 2 full point's in compression, that is crazy to think that. Most of it is the turbo, the torque graph shows you that boost is coming on later, there is no way a sub 2 point drop in compression paired with 24 extra cubic inches is going to cost you 150 ft-lbs.
I agree. Pretty sure the pass turbo is doing nothing for me right now, going to test that theory tonite!
Yep! I did verify that the same thing did not happen this time; everything is hooked up and moving properly. Gonna fake out the driver's side turbo into not building boost, that will tell me quickly!
- Dug
- Dug
Does anybody have ANY idea what it might cost to have this type of turbo fixed?? Or recommendations of who? I'm thinking of Limit Engineering in Lake Havasu AZ
Gary
11 & 7 Second Clubs
Originally Posted by bickelfirebird
BTW, I would have no hesitation asking APE to build a motor for me.
- Dug
Originally Posted by TwnTrboCE
I guess you'll find out with your test. But I don't think one turbo can support almost 600rwhp. How much timing were you at with the old and new?
Originally Posted by 99BackNBlackZ28
Did you test anything tonight, Dug?
- Dug
Enthusiast
1 Post
Dug,
Did you check both actuators to make sure they are hooked up and opening at the same time? Then just run thru the system and make sure none of the hoses blew off. Mine would blow off at the driver side inlet to the *** pipe.
For the passenger intercooler, drill a small hole on the front lower section of the bottom tank and drill and tap for a 6mm bolt as a drain hole. Open the hole, put a drain pan under it and start the car. Most of the oil in the hose from the compressor to intercooler will be forced out. I would replace the oil check valve as I know my car and Mike's car both had them stick open while sitting for extended times. The cartridges themselves started coming with restrictors built in at the time of the LS1 kits but LPE adds about a .026 restrictor to each oil inlet of the turbo if memory serves me correct. The only other oil issue i ran into is with the use of the weldon pump. If you are using this scavenge pump, you should also be running a one way check valve (maybe .5 psi crack pressure) between the pump and the oil pan so the oil cannot run back down to the passenger turbo while sitting.
On another note, what was the reasoning on the camshaft you went with?
Hope this all helps and I will keep thinking a little deeper on this.
Tom Porter
Tom Porter
Hey Tom, thanks a bunch. Found out yesterday why the driver's turbo is not boosting. The damn actuator is REALLY loose. Only one bolt holding the bracket to the turbo, and it's stripped. Murphy's law. Can't get a tap in there so I'm thinking of a self-tapping bolt, and then use the existing bolt in the other hole. That should fix that.
You know, I was going to ask you what prevents oil from draining back through that scavenge pump into the turbo . . . where would I put that checkvalve? One the connector that goes into the oil pan? Any suggestions on where/what brand checkvalve?
I picked the camshaft I did after calling Cam Motion and Comp Cams. They asked me a bunch of questions, I gave them the answer, and they both spec'd out pretty well identical cams. Do you have another suggestion?
I found the actuator problem while running my tests . . . when only the driver's turbo was boosting, it almost went to redline just to see 5psi when the controller was set to 10.
- Dug
- Dug
