Twins vs. single turbo....
Jose
Jose
Thats why Im curious as to why some still perfer twins
Some have said the twins can be more efficient due to the fact they are mounted very close to the hottest part of the exhaust directly by the heads and that a single with a crossover can lose velocity. Singles have become very popular due to the fact they it most classes only allowa (1) power adder. It is also easier to rig up some plumbing for a single. Probably the biggest advantage of a twin setup is the visual appeal and saying Twin's. Take what you read and you be the judge. I am doing three twin turbo cars right now just to give an idea of how popular they are here in Wisconsin!
if as i suspect, you want to run a 6 speed, that mid range torque is really important, esp after the shift and your rpms drop fast and you loose boost/torque. twins will provide that more instant power/torque. but you have all that extra piping, lack of space, and cost.
overall, i doubt you want a true track car but i still think a big single is gonna be awesome. esp if i am right in that you would be running from a roll where spool time and midrange hit isnt as much of an issue?
don't forget about Ill Nitro!
I saw on another board where a person had a ball bearing T76 with a 383 lt1. The car mad I think 5 pounds of boost at something like 2800rpm and had over 500 lbs at the wheels at about the same rpm! I think that was NOT even full throttle. That is enought low rpm boost and power to where you would just burn even 315 tires. If I recall , that was only at a small throttle percentage.(I think he had throttle % data on his FAST to tell what throttle percent it was). Even smaller 302-306 mustangs can spool something like a T76 pretty well.
If you want to go bigger than that to something like a T88.... If it is a smaller cube , stickshift street car, twins may be more responsive , but then you are talking about the 1250 -1300+ fwhp hp level before you NEED a T88. Both single or twins will make the power. As far as size , some cars are set up to where it would be easier to fit a single because you have room in a certain space to fit it, but not enough room in other places to fit 2. Other cars (even on the same type of car sometimes) may have room for two smaller T66's,but not enough room for one big T91, depending on your underhood space and how you have things spaced , relocated, what K member , accesories etc.
Also some people just like to say I have twins , or have 2 sitting there when you pop the hood. Although a huge 101mm turbo is starting to have that same "eye" appeal to SOME lately.
Seriously. One guy is gonna be envious when the other guy says he has "Twin Turbos". When really his setup is just fine and more efficient.I just happened to end up with twins because an opportunity presented itself and I didn't have to worry about installing it either. I was originally going to go with a larger single turbo, but PTK and HP have been sitting on their asses and I dont want to tear my car down in mid summer to redo it. So they will have to wait till I outgrow this one.
later,
Dave
but i mentioned the hot side. isn't that 3" for the 60-1's? if that's what i ultimately end up going with. we haven't fully discussed this yet, so i was kinda guessing.
thanks,
Dave
Youre also right about a STREET car. Itll probably see the track once a year. I like going, but Im setup for the street being lowered, 18s, stiff shocks, etc...Roll... dig... its all good
i thought twins would spool faster, but my T76 got to 10psi quick
then i though just what you could route easier. well, then i discovered you can route a single easier. I think you could route one 4" downpipe easier then two 2.5" downpipes. while the 4" has more area, 50.3 CI compared to (2*19.6) 39.3 CI
then a few pricing checks, if you want ALOT of power a single will be cheaper.
Then i looked at the big dogs who were running some real wicked fast times, those guys have singles.
and also alot of race classes, dont alow twins
so i concluded that a single is better then a twin.
but you will always have those people who just like the name twin turbo, but i think its the same thing as saying you have twin NOS, ok so you have twin nos, sure its ok but not needed just a bling factor.
