Incon Turbos - Wire Only One Shut?
. Neither one would tighten. I've about had it with this ****. Can I wire the driver's side shut, but leave the actuator on the passenger side? There is no way I can tap those holes unless the entire driver's comes out, and believe me, that ain't no picnic.If I wire it shut then the driver's side would do most of the work, and the passenger would be doing less I assume. Can this cause a problem? I'm thinking not, but need your thoughts.
- Dug
- Dug
i don't know for sure but could'nt that cause reversion on the intake side of the turbo that does not have the wastegate wired shut? just my .02
gary
I still may throw it on the dyno with both wired shut ( take me 1/2 hour to do it, if that's too much boost I've only lost 1/2 hour and a dyno session. THEN I'll pull them both out and have them checked over.
- Dug
Gary
- Dug
Anyone have any ideas???
2fast4u . . . have you verified that they actually start opening at 7psi, using a mityvac or something? Can the rods screw in/out to adjust like mine can? I think I can vary up to 2psi with mine.
- Dug
Well I haven't checked the actuators and they are adjustable. But even with a cheap screw type boost controler I only got another LB. out of it!
Oh and the BMR A-arm will automaticly lower the front of your car 1". If you have Hals turn them up if you don't you can buy the BMR shock spacers.
