Procharger F-1 Help
Old Feb 24, 2005 | 03:37 PM
APD*98SS's Avatar
Default Procharger F-1 Help
I just upgraded to an F-1 Head unit and there is not much room to filter the inlet of the blower unit. Any suggestions on a type of filter system or do I have to find a metal fabricator to move the radiator forward some??? 1-2 inches is all I need...
Or any other ideas would be greatly appreciated
Old Feb 24, 2005 | 03:46 PM
Wild85's Avatar
Move the rad forward. Sounds best to me!
Old Feb 24, 2005 | 09:05 PM
APD*98SS's Avatar
Anybody have any pictures???
Old Feb 24, 2005 | 11:15 PM
BIGBOS's Avatar
I had the same problem on my f-body, I never ran a filter, but the radiator would have to be moved foward to fit one.....I know they sell 90 degree bends, but that still wouldn't fit....
Old Feb 25, 2005 | 12:47 AM
LSs1Power's Avatar
How much space do u have left now? Take a pic if u can. Did u ever think about the HKS filters?
Old Feb 25, 2005 | 01:11 AM
BIGBOS's Avatar
If you look in my webshots photos you might see some......but I heard about the "HKS" filter, I don't know how tall they are thats why I never tried them.....
Old Feb 25, 2005 | 01:22 AM
LSs1Power's Avatar
I think its going to look like a hat over the blower inlet. It looks you need around 2" clearence to fit the HKS filter. Here are some pics for it http://www.importcarpartsplus.com/In...ksMegaFlow.htm
Old Feb 25, 2005 | 01:39 AM
APD*98SS's Avatar
The HKS wont fit either, it's pretty tight. Some of you are fmiliar with moving the radiator, if so please chime in...
Old Feb 25, 2005 | 01:47 AM
BIGBOS's Avatar
There was a possibility of putting a notch in it, its custom fabrication work, but thats the only way to get room to squeeze one in
Old Feb 25, 2005 | 01:53 AM
APD*98SS's Avatar
I took my fan shroud completely off and even trimmed 1/4 inch off of the inlet hat ring and still no luck on the inlet hat over the F-1 it's just too damn big.
Old Feb 25, 2005 | 12:12 PM
Bryan Wilkinson's Avatar
Went with a redesigned Radiator from evans cooling. Dim were 28 X 2 5/8 X 14, Dual Spal 11" fans. Fans are on a switch that I activate when I want them on. I cut them off above 35 MPH and when I am not driving around town. I raised the radiator and it allowe me to run a tube under the radiator that was 4" in diameter. Radiator is good for 475HP. Being that I dont use all of the power all of the time, I did not require a 900hp radiator, which no one would be able to fit in their car.
Old Feb 25, 2005 | 03:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What about:
http://shop.airflowonline.com/Mercha...egory_Code=CE2
I got a 4"/4" one I am going to try on my car this Sunday when I do some wrenching.
Old Feb 26, 2005 | 12:44 AM
APD*98SS's Avatar
Pro Stock John,
Good looking out, I ordered one tonight. Its pliable so it should be easy to sqeeze into place...
Old Aug 1, 2005 | 01:38 PM
Blown408's Avatar
Did any of these work for the F1?
Old Aug 1, 2005 | 03:21 PM
APD*98SS's Avatar
Not no but He*l no... The soft rubber could not stand up to the suction of the impeller blades... Instant cavitation of the elbow under acceleration...
Old Aug 2, 2005 | 05:57 AM
Blown408's Avatar
So the only options are no filter at all, or relocate/move the radiator?
Old Aug 2, 2005 | 06:07 AM
Wet 1's Avatar
... or sell me your F1R cheap since it will work great on my vette!
