MAP Sensors
Old Mar 9, 2005 | 12:48 PM
Juiced's Avatar
Default MAP Sensors
At What Boost Level would you all recomend swaping the MAP for a 2-3 bar map, what is the limit for the stock MAP.
Old Mar 9, 2005 | 01:01 PM
MECHAM's Avatar
i think some already replied 1 bar
Old Mar 9, 2005 | 01:26 PM
smokinHawk's Avatar
switching the map sensor would only be good if you upgraded to the HPT 2 or 3 bar setup,
two bar will get you up to 14.5psi, three bar will do up to 29psi
Old Mar 9, 2005 | 01:35 PM
Juiced's Avatar
IS that 1 Bar Above Ambient Pressure?
Old Mar 9, 2005 | 01:55 PM
Boostaholic's Avatar
EDIT : Horrible mis-information removed!
Old Mar 9, 2005 | 02:02 PM
smokinHawk's Avatar
Originally Posted by Boostaholic
Yes, you can run 14lbs of boost on a 1 bar map.
no the sensor wont read that,
the GM 1 bar sensor will only read -14.5 to 0 psi (gauge)
2bar gets you -14.5 to 14.5 psi (gauge)
3bar -14.5 to 29 psi (gauge)
so one bar reads atmouspheric pressure and not above
Old Mar 9, 2005 | 02:18 PM
Mike 01WS6's Avatar
False, you need to run a 2 bar MAP sensor for that. If tuning with just the stock MAP, you can run nothing but naturally aspirated.
The natural atmospheric pressure forces 14.7 lbs of pressure into the engine.
Without this pressure our bodies would literally explode, just like in space, because there is no pressure in space; space is a vaccum, much like when your engine gobbles up pressure given to it by the atmosphere, it reports a vaccum if you have a vac. gauge on your N/A car.
1 bar of actual boost would be an ADDITIONAL 14.7 lbs of of pressure, or in this case just 14.7PSI on the motor as the boost gauge registers it. It get confusing when using MAP sensor terminology to some, because you start out at -14.7psi.
So here's the breakdown:
-14.7 to 0 PSI: 1 Bar MAP
0 to 14.7 PSI: 2 Bar MAP
14.7 to 29.4 PSI: 3 Bar MAP
Old Mar 9, 2005 | 03:17 PM
smokinHawk's Avatar
1 bar = 14.5psi
1 atmosphere = 14.7 psi
1 kpa = .145 psi
100 kpa = 1 bar
Old Mar 9, 2005 | 03:28 PM
APeteSS's Avatar
Not too tough if you think in KPA
Old Mar 9, 2005 | 04:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can't just add a 2bar sensor to the stock pcm, it won't work. The HPT stuff works because of what they have done to make it work.
I run a 3bar with my BS3.
Old Mar 9, 2005 | 11:49 PM
Green Thunder's Avatar
Hey John,
What 3-bar did you go with? Accel?
Old Mar 9, 2005 | 11:58 PM
Thanks for the info! I did not know that, always thought it would mesure up to pos 14.5 but also the same negitive amount.
Old Mar 10, 2005 | 05:44 AM
smokinHawk's Avatar
though looking at our primmary VE tables it list 15kpa to 105kpa, this being absolute pressure our 1 bar map sensor effectivly reads pressure to -12.5psi to .5psi (gauge)
so you can boost .5psi and not worry about it
Old Mar 10, 2005 | 04:08 PM
LS1Tech Co-Founder
I'm running the 25th TA 3bar.
Old Mar 10, 2005 | 04:33 PM
Guess I better order some new wastegate springs then!!
Old Mar 10, 2005 | 04:45 PM
strokedls1's Avatar
Good information. Thanks for posting it up guys. Learn something new everyday.
Old Mar 10, 2005 | 06:41 PM
Didnt realize GM used one on TA! Wish I had realized that! I went with a accel 3 bar...
Old Mar 10, 2005 | 08:06 PM
89 Turbo TransAm
Old Mar 14, 2005 | 03:15 AM
2001FireBird's Avatar
Is anyone currently selling a 3 bar map sensor?
Old Mar 14, 2005 | 05:17 AM
smokinHawk's Avatar
here is one i know of
http://home.att.net/~alkycontrol/page3.htm
