Major Misfires! Please help ME!
Did you clear the code when you swapped coild and the harness? ALot of the times you have to clear them by a scan tool and not by disconnecting the battery.
Usually that code will not come from a non-ignition problem and its a wiring problem, check all the coil wire routing and make sure nothing is pinched/worn through. If you seen some bare wires under the coil pack there is a good chance it may have damaged the PCM also. Sometimes the wrong cylinder gets reported on those p035x codes so make sure you are troubleshooting the proper cylinder. Its the one that the header tuve will be a lot colder then the rest after its been running.
99% of the time it was bad wires, id replace them and it was fine.
one time i replaced them, it didnt fix it. my father said shut the lights with the car running, and look around.
You would not believe me, but i had sparks jumping to every metal to metal i could find. hoses and brackets. it was nuts, i put tape or wire hide in between everything and it was fine. what caused it. not sure, but i would guess a wire that i could not see was hitting someplace. very strange, but it worked
pressures (high dynamic cylinder air value). If it's too
little gap it will show (I think) at the fat-fuel, slow-burn
corners. Might try logging the misfire-current values and
stuff like MAP, RPM, CylAir, and try scatter-plotting them
in Excel; any "normal" PID that seems to group the misfires
into a distinct line, cluster, whatever, can be a useful clue.
I have seen that before. Than I will switch the coil pack sides and see if it switchs if not it is something in the female side of the harness to something. But what i dont understand, It that if it is after the coil packs, It couldn't be ground, Why would only one coil miss? This sucks My car had a low speed misfire on #8 for 2 1/2 years. Tracked the root cause to a cross-threaded spark plug of all things
I A-tapped the car once it was buttoned up, and the chronic misfire was gone, #8 fires at 100%.
Not suggesting this is you car's problem - but just pointing out don't discount any detail. Low speed misfires should be very infrequent and random, if they occur at all.
