BOV for P1-SC questions
1. I've heard alot of praise about the HKS SSQV, but is the ATI Race ready better in terms of sound and performace? I would rather get the ATI then the HKS since its not rice made, but if the HKS is better sounding or performing i would get that of course.
2. I notice at 2k rpms and below, im in the vacuum or at 0 if im accelerating, is this because my bypass valve is venting the boost, would the BOV give me more boost at that range because its adjustable and i can adjust to be less sensitive to vacuum? Is there any power gains over the stock bypass?
3. Whats the best route in terms of fitting it? I see a lot of people weld it on their air box, that looks really nice, is that the best way to go? is there any particular place to put it where it would be most beneficial? I know it has to be before the MAF. if i would get one i am thiking about getting it welded to the air box, and get a straight pipe instead of the bypass valve.
4. If i am in vacuum, is the BOV going to be open and sucking in unfiltered air? how do people go around this? Is it possible to fit a small K&N filter on it?
thanks!
ultra annoying.
heres the video of that:
http://home.comcast.net/~jsbird1998/mondoatthetrack.mov
theres a Tial also, which sounds liek what you are describing, chirping and fluttering, i dont like that at all.
http://www.itlxlr8.com/vids/BOV.wmv
I just want a woosh sound similar to the turbos. And hopefully unlock some boost, if thats possible.
The first vid is FRCEFED98's and it is the Vortech Mondo.... he had the HKS BOV and ANY BOV will sound like the 2nd vid (my car) That is the Tial 50MM BOV. WE both were selling the BOV's and going with a BYPASS.... a BYPASS is what you wil need. Either the ATI or the Vortech. Any BOV will chirp at cruise like you heard in my vid. I was going with the Vortech after hearing it on FRCFED's car.... i had the flange welded on and was about to order the Vortech bypass when i decided to sell the whole kit and go turbo.
Thats about all ya need to know..... DONT buy a BOV for your SC setup......
Kyle
Exactly.............................
Kyle
No bov for me then.
As far as the Mondo and the ATI RaceReady, is there any power to be gained from swapping from the stock, or is it purely for sound? How does the ATI sound?
I found the Mondo valve on ebay and as well as summit. if i was to buy it, how would i get it connected, it has a weird oval shaped inlet, is it going to come with all the necesarry hardware to get it welded to my air box?
You can bypass it back into the inlet hat, you will need a two inch hose tho, or you can blow it off into the atmosphere which sounds awesome. You will have to plug the inlet hat where the stock bypass use to vent to, but thats easy.
Its freakin huge so space to mount it is tight
http://www.vortechsuperchargers.com/...tegory_Code=AC
Same flange i used... went on easy......
Kyle
thanks
Here is a couple more pics, you can see the advanced auto hose part number I cut apart to make it go back into the hat. It doesnt move as much air as a mondo or ati race bypass but its plenty for a P1SC, I was running a 3.2 pulley also.
