98 MAF Max
Old Mar 26, 2005 | 11:31 AM
Ryan K's Avatar
Pathological Modifier
Default 98 MAF Max
Sure isn't hard to max out a 98 MAF. 439.2g/s Comes up quick. What is the best method for increasing its range?
Ryan
Old Mar 26, 2005 | 11:56 AM
kp's Avatar
kp
descreen/port the MAF or do the resistor trick. I have used the resistor trick and it worked pretty well up to ~9psi. Steve (s_j_h) wrote up a while back how to do it, I'll be doing it on this car as well
Old Mar 26, 2005 | 11:59 AM
MECHAM's Avatar
i havent touched my stock screen maf
Old Mar 26, 2005 | 01:36 PM
Ryan K's Avatar
Thats nice, what is your max frequency? How many g/s? I know that I have hit the ceiling for max frequency on my maf. I know you are running some serious numbers, how did you get around it?
Its already descreened, but not ported in any way.
Ryan
Old Mar 26, 2005 | 01:40 PM
slow's Avatar
I plan on the resistor trick, unless somebody who can make GM maf's comes out with one that flows 1,000 g/s @ 11,000hz
Ryan
Old Mar 26, 2005 | 03:22 PM
MECHAM's Avatar
I have a 98 too..so its the same as yours...i just add more fuel.
im really in need of a "real" tuner tho
Old Mar 26, 2005 | 03:29 PM
Ryan K's Avatar
OK then your MAF is maxed too, you just tune around it. Thats what I have been doing, there just has to be a better way.
Ryan
Old Mar 26, 2005 | 03:31 PM
~RedLineLs1~'s Avatar
Who tunes your car as of now? Just curious.
Old Mar 26, 2005 | 08:35 PM
MECHAM's Avatar
<-- this idiot
Old Mar 27, 2005 | 03:00 PM
frcefed98's Avatar
HP tuners was or is releasing its 2-3bar map set up for the 98's at a later date, but haven't heard much on that topic other than the announcement of the 2-3 bar map SD set up. It could be out as I haven't hit their site up in a few weeks. It is currently out for 99+ I think.....it was the whole reason I got HP tuners tuner, but....like everything I buy I have to wait to use it for the reason I bought it for some reason or another
Other than that its the ol add fuel once the MAF is maxed deal..no solutions have been made to fix this problem on our FI rides...which is pretty weak since this has been a problem for a few years already.
Old Mar 27, 2005 | 05:58 PM
MECHAM's Avatar
i too have went with HP TUNERS..in hopes that the SD software will be released for it soooooooonnnnn.
now i just need a tuner to help me with it...
Old Mar 28, 2005 | 11:13 AM
MECHAM's Avatar
ok..so yeah...this has me really discouraged...guess i changed to hptuners for nothing...
http://www.hptuners.com/forum/YaBB.p...num=1111247845
Old Mar 28, 2005 | 11:29 AM
smokinHawk's Avatar
sell your car and get a 99+
Old Mar 28, 2005 | 11:44 AM
chris99gmc's Avatar
well I have a 99+... but it's a truck. I was maxing the maf out on the dyno at around 10psi.
I'd like to know a solution without having to swap it out.
Old Mar 28, 2005 | 11:55 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yah 98 is the orphan year.
B
S
3
BS3.
Old Mar 28, 2005 | 12:00 PM
Ryan K's Avatar
BS3 with Trans Control, without internal DAI, $2495.00 OUCH! Its just a hard bullet to bite.
Ryan
Old Mar 28, 2005 | 12:01 PM
MECHAM's Avatar
B
S
3
BS3.
waiting for u and MM to work out all the bugs
Old Mar 28, 2005 | 12:02 PM
Ryan K's Avatar
Originally Posted by Chris@HPTuners
Sorry, we don't have an answer at this time. Unfortunately the 98 code is not as consistent to work with as the later code. Also, a number of other features (or lack of) in these PCM's makes it very difficult for us to actually deploy the 2bar program. We are working on some possibilities, but i have to say it is not looking good.
Chris...
Yeah not really a confidence builder.
Old Mar 28, 2005 | 12:04 PM
LS1Tech Co-Founder
I have no bugs. I"m making 754rwhp at 6600 with unlocked 'verter and maxed out 83's at 50 psi base fuel. Sure sounds like 950 at the crank to me.
Old Mar 28, 2005 | 11:12 PM
frcefed98's Avatar
Man, always my luck. The SD 2-3bar set up was the main reason I made the decision to buy HP tuners...already had efilive and traded it in. So now it looks like us 98 guys are shafted by default. Damn 98's DAMN YOU TO HELL Someone will get it figured out..unfortunately it looks like I'll have to save up to get a BS3 or FAST system...at least the local tuners can tune with the FAST set up pretty easily.
