Piston Oil Squirters
SC-
Ahhh...we'll just stick with the right tune up then. In theory it's a great idea, and if you have a system designed properly as to where it won't rob the main and rod bearings of of proper oil, it would be a good way to find more power.
On a pure drag race motor I think it would just add to windage, something most builders try to control. But on a motor that has to run at high boost levels for a extended period (road race, ralley) of time I can see where it would help.
These engines will happily make around 500bhp+ with few worries.
Ford Sierra Cosworth engines ( UK 2.0 4 cyl ) also have oil squirters, but of different design. They have a small tubular rail taken from the oil pump, which directs oil jets to the underside of the pistons.
Again, these engines can readily make 500bhp+ with few worries.
As already mentioned, Porsche have been using them for years.
Most oil systems should easily cope anyway. If the oil pump can flow enough at say 2000rpm, how much more oil will it flow at 5000rpm ??? Most of it gets dumped via the relief spring anyway. Adding a few oil squirters shouldnt hurt.
Other question is, are they really needed in the first place ??? Even 7-800bhp FI on an LS1 is relatively mild given engine size.
Definately, but it's the added factor of staving detonation due to the cooling effect of the oil being put directly to the piston skirt. Less det. more timing, more power.
