Question
Old Apr 11, 2005 | 08:37 PM
ddnspider's Avatar
Originally Posted by HellRaiser
yes true. But most of them is from not getting the car tuned right and running to much boost on a stock block. The budget kit is for 5-6psi around 450hp the wheels with that tuned I would think the car would last a long time.
and with an FMIC 8psi
Old Apr 11, 2005 | 08:41 PM
~RedLineLs1~'s Avatar
Originally Posted by MetallicaMatt
also, is this kit reliable? i'm a little nervous about "budget" this and "budget" that.......just want to make sure i'm not buying crap
Its not crap. Its basically labeled as a budget kit because the kit uses stock exhaust manifolds and the cost is cheap. Phamspeed does some very good work.
Old Apr 11, 2005 | 08:42 PM
HellRaiser's Avatar
Budget just means the kit use's stock exhaust manifold's got here to see the other kit that comes with Phamspeed exhaust manifold's. https://ls1tech.com/forums/showthrea...kit+came+today
go to page 2 there good pics there.
Old Apr 11, 2005 | 08:46 PM
HellRaiser's Avatar
here.
MetallicaMatt's Avatar
is it worth it to get an upgraded kit?
I have a catback exhaust, will it effect the sound of it?
Old Apr 11, 2005 | 08:51 PM
how much of a PITA will this thing be to install myself?
Old Apr 11, 2005 | 09:05 PM
The budget kit looks like a piece of cake to install. with The other kit the manifolds will be somewhat time consuming. The oil lines will probably be the most difficult thing on either kit.
As for the upgraded kit, it all depends what you want.
Old Apr 11, 2005 | 09:15 PM
any big gains? its quite a bit more it looks like
Old Apr 11, 2005 | 09:35 PM
Not quite sure what the gains will be over the budget kit because there arent any numbers or track times for either kit, but the budget will be able to yield you quite a bit of power. If you're only aiming for 450-500 and nothing more, i dont see a reason to go with the upgraded kit. The budget kit will get you there just fine. If you're planning something major or would want to upgrade later, you should just get the upgraded kit.
Old Apr 12, 2005 | 05:27 AM
400-500rwhp would be enough for me!
i still can't believe the rear end can handle that, but thats fine with me!
anybody have an idea what ATI would cost me anyways?
Old Apr 12, 2005 | 05:52 AM
smokinHawk's Avatar
hell ill be under $4k when im done with the phamspeed kit!
haaaaaaaaaaaaaahhhhhhhhhhhhaaaaaaaaaaaaahhhaaaaaaa aaa
funnyest thing ive heard all day.
you are forgeting one important thing young grasshopper FI is a drug more addictive then crack cocaine. any amount you think it will take to build your car plan on doubling that amount, you will soon be spending over 8k once your halfway done, because you will never be done.
Old Apr 12, 2005 | 07:50 AM
  #32
ddnspider's Avatar
ah wise words from teacher...BUT!ill have to be content for awhile cause a stock sb will only handle so much,so its sort of like my wallet has a redline for now because of the block......although i do have that raceprepped LS6 block i been trying to sell....guess thats always an option
Old Apr 12, 2005 | 07:50 PM
  #33
will my Borla exhaust sound the same?
If i go with STS, it interfers with the exhaust or something doesn't it?? i love my borla too much to loose it
Old Apr 12, 2005 | 08:11 PM
  #34
STS will eliminate your exhaust. This kit will keep it.
Old Apr 12, 2005 | 08:16 PM
  #35
ddnspider's Avatar
thats no entirely true it will have to be modified if you get the budgetkit
Old Apr 12, 2005 | 08:17 PM
  #36
You will just have to connect the dp to the exhaust. It doesnt take the cat-back away.
Old Apr 12, 2005 | 08:44 PM
  #37
HellRaiser's Avatar
This is what I am going through right now. I just don't want to bolt up the kit and run a little I want alot so I pushed back the install till a later time. Way later time lol
Old Apr 12, 2005 | 09:18 PM
  #38
TTSSZ's Avatar
Just wait till you find out on the dyno (add $500 for tune) you need a $4g fuel system just to feed that thing.
Old Apr 12, 2005 | 09:30 PM
  #39
ddnspider's Avatar
already got a pump,injectors are $250,got 4-an lines,and the dyno will only be between 100-300.you gotta remember im converting from N20 to boost not stock to boost so ive already got some upgrades.
Old Apr 13, 2005 | 02:33 PM
  #40
now I want a turbo
now I need cash
