if i built my own turbo kit would it pass smog?
how would it be considered smog legal if there is a carb # on the turbo does that make it legal any help would be appreciated.
12 Second Truck Club
There are no CARB exempt turbo kits on the market as of right now. If you build it then you would have to submit a request then spend over $100k to get it a CARB #. LOL
Originally Posted by potholesrbad
so are there any smog legal turbo kits?
The closest it STS but until they get the # don't hold your breath. They are easy to remove though so smog isn't as hard to deal with as with front mounts IMO.
Originally Posted by sb427f-car
Here's a suggestion, MOVE, lol. J/K. Cali is sooooo stupid when it comes to some stuff.
SSU'S Vice Mod
Just remember that you won't make big HP and stay smog legal with an ATI either. Smog is the anti-HP
no, smog isn't the anit-hp, those stupid regs are the anti-hp. I bet you could still pass sniffer tests with the blower. BTW, are for the hippies
i worked for a local hotrod shop last year for about 8 months my boss had a 87 5.0 ttop at mustang that ran a 12.9 @80 not going into overdrive and blowing the blower belt off at 1000' he passed smog better than a new car at a test only station he bought a western motorsports computer where you put all you own maps in so u can make it have 600 hp or 300 hp he was running 10.5:1 w/ 6psi svo ported heads trickflow intake co2charged intercooler he did put his cats back on to pass smog as long as everything you add has a carb # and you have a good tune im pretty sure it will pass.
the test only stations are bad they call every carb # in to see if its legit you timing has to be set at the stock stting my friends truck got failed for being at 18 degrees instead of 16 degrees
