AFR's on boost
Old Apr 18, 2005 | 10:33 PM
  #41
Reckless's Avatar
Super Moderator
"Cheap" and "Kurt" should not be used in the same sentence
Old Apr 18, 2005 | 10:44 PM
  #42
NA$TY-TA's Avatar
Todd you know i didnt mean it that way I was just wondering what he recomended and how much$$$
Kyle
Old Apr 18, 2005 | 10:47 PM
  #43
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Interesting info, thanks for posting this stuff Kurt. My 6.0's are coming off after this year.
Old Apr 18, 2005 | 11:51 PM
  #44
Jammer's Avatar
Kurt, hasnt been said in a few months..so here ya go..
you da man
Old Apr 19, 2005 | 12:05 AM
  #45
BLk01SS's Avatar
So you think that the All Pro's are much better than the AFR's or about the same?
really looks like price is within a hundred or so.
Which would you recommed for a 1000rwhp setup?
Thanks,
Tre
Old Apr 19, 2005 | 09:55 AM
  #46
NA$TY-TA's Avatar
Thanks,
Tre
We will see that is why he is testing them both.
Kyle
Old Apr 19, 2005 | 10:57 AM
  #47
427's Avatar
427
Todd,
I can live with that.
Nasty,
I will have someone PM you for the specs of the head you want.
PSJ,
No problem, I live to test!
Jammer,
I need a bigger helmet now.
BLK01SS,
They are both good heads. I would use the all pro for that much power based on material type and deck strength. They also will hold the valvetrain more stable.
Kurt
Old Apr 19, 2005 | 11:19 AM
  #48
kp's Avatar
kp
I thought Kurt was very reasonable on the price he gave me for the last short block. A little more then most (and I talked to a lot of shops) but it was well worth it when I decided no to go through on finishing my short block because I sold the car - I had sent a good sized deposit and could not be more pleased with how the matter was settled. I was very very happy with the service I received overall and realistic time frame. If I decide to do another 'real' LSx motor there is no doubt W2W will be the one doing it.
Sometimes saving a few hundred bucks on a motor isnt worth it in the long run Dont be scared to give Kurt a call, you may be surprised what it costs compared to others.
Old Apr 19, 2005 | 11:40 AM
  #49
smokinHawk's Avatar
neither should "hair" and "todd"
Old Apr 19, 2005 | 12:16 PM
  #50
NA$TY-TA's Avatar
Old Apr 19, 2005 | 12:27 PM
  #51
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by Big Mike
That wouldn't be Andy Jensen you are reffering to, would it??
NO!!
And I'm impressed Big Mike. You are the first person to pick up on that here. You know him/seen him in action?
Old Apr 19, 2005 | 12:59 PM
  #52
Big Mike's Avatar
Originally Posted by sb427f-car
NO!!
He races against my cousin in Pro Mod (East Coast Doorslammers). I've seen that car take out 632ci. NOS cars like its nothing! I know that blue car is ULTRA light. That car is amazingly fast for such a small motor and the car goes pin straight! Here is a picture of my cousins car, which is usually racing when the Jensens are.
Old Apr 19, 2005 | 01:08 PM
  #53
sb427f-car's Avatar
SSU'S Vice Mod
The car in my avatar is their new car. Are you thinking of the old car? The 468 SB on a big hit? The "undercover" pro mod car which was really a full tube, out law street car? (hell he even had it tagged in PA, and I think they still run it some). You're right, about the new one, carbon fiber everywhere. I'll try and post up some pics tonight from home of the new one. Every time I saw them @ cecil last year they couldn't keep from shaking the tires before the 330, else they woulda been running consistant 6.50s @ their 214 trap speed (in the heat of the day mind you). Problem is, no one ever beats Halsey @ Cecil Co. cause they own the track. Nothing like having unlimited testing @ one venue.
Old Apr 19, 2005 | 06:55 PM
  #54
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Another plus about Kurt and Wheel is you don't have to worry about your money disappearing or missing your build date.
IMO they're the most capable sponsor on this board.
Old Apr 19, 2005 | 09:43 PM
  #55
Big Mike's Avatar
The car in my post beat the Halseys a few times!!
Old Apr 19, 2005 | 09:44 PM
  #56
sb427f-car's Avatar
SSU'S Vice Mod
Is that Halsey's Camaro in the far lane? Yeah, but have they put them on the trailer @ Cecil Co.?
Old Apr 19, 2005 | 09:48 PM
  #57
Big Mike's Avatar
Yes, at Cecil and Virginia!! My cousin has beat Castellano, Bodano, Musi, Halsey, Dantoni. The new setup is a Musi 734ci with 3 stages!!!!!!!!!!
Old Apr 20, 2005 | 10:53 AM
  #58
sb427f-car's Avatar
SSU'S Vice Mod
geeez. Well...yall gonna be there in two weeks for their first shootout? Last year I never saw anyone come close to chalenging halsey @ cecil funny, he's the "hometown" boy too.
Old Apr 20, 2005 | 12:19 PM
  #59
Bryan Wilkinson's Avatar
Originally Posted by 427
Ran some tests on a 5.7 engine built for drag racing. We are finished with the AFR portion of the test and should be testing the All Pro next on the same shortblock.
Heads: AFR castings ported by ET performance for forced induction. 2.055 int 1.6 ex.
Intake: GM performance parts alum carb intake.
Camshaft, valvetrain: Cam Motion solid roller, jesel lifters. jesel 1/2-7/16 pushrods and Jesel custom rockers- 1.7 ratio.
Had planned on testing at 35psi, but the gates are causing surging that limited us to 30psi.
Peak Tq was 1208 at the flywheel @6000rpm (from my memory on rpm)
Peak HP was 1697 at the flywheel @7500rpm
Generally the head seemed very good with the head gaskets showing no signs of problems. I did weld all the water holes shut in the heads and then drilled them to match the SCE gasket to gain some surface area.
Kurt
It would be nice to see the dynograph for this run. Perhaps you could post it.
Old Apr 20, 2005 | 04:00 PM
  #60
Kevin@W2W's Avatar
LS1TECH Sponsor
Ask and you shall receive.
