AFR's on boost
Old Apr 20, 2005 | 07:01 PM
  #61
SScam68's Avatar
Originally Posted by Kev@WheeltoWheel
Ask and you shall receive.
GOOD LORD!!!!!
Old Apr 20, 2005 | 07:36 PM
  #62
WS-Sick's Avatar
That is...
Old Apr 20, 2005 | 08:01 PM
  #63
Bryan Wilkinson's Avatar
Kev,
Please tell Kurt that I stand corrected as he is the MAN!!!!,
That is unbelievable. 30PSI on a 352CI. outrageous!!
Congrats.
Sincerely
Bryan Wilkinson
Old Apr 20, 2005 | 08:12 PM
  #64
sb427f-car's Avatar
SSU'S Vice Mod
"Huston, she's cleared the tower and is all your's."
DAMN! And this is on 352 cubes. Imainge if they were to go 400+ even more insane. Although, Kurt, if you care to share, how are you making those 352"? Are you a big bore with a short stroke to be able to spin and take advantage of an unshrouded/big vavle?
Old Apr 20, 2005 | 08:20 PM
  #65
Anonymous's Avatar
10 second playa
Originally Posted by Big Mike
He races against my cousin in Pro Mod (East Coast Doorslammers). I've seen that car take out 632ci. NOS cars like its nothing! I know that blue car is ULTRA light. That car is amazingly fast for such a small motor and the car goes pin straight! Here is a picture of my cousins car, which is usually racing when the Jensens are.
Mike your cousins Pro Mod is HOT!
That is the first time I have seen it.
When is he racing in NJ Again?
Old Apr 20, 2005 | 08:23 PM
  #66
sb427f-car's Avatar
SSU'S Vice Mod
Anyon. Most of the East Coast boys will be @ Cecil Co. in Rising Sun MD in two weeks (May 7th I do believe). Not sure if they'll be there or not but most likely they will.
Old Apr 21, 2005 | 12:33 PM
  #67
sb427f-car's Avatar
SSU'S Vice Mod
Ok, as someone mentioned in the regular LS1/6 engine section, are the All Pros W2W is going to be testingon the factory valve angle, or a revised, or what? Does AFR offer various valve angles?
Old Apr 21, 2005 | 08:01 PM
  #68
Big Mike's Avatar
Just found out this afternoon. We will be there! All 734ci and 3 stages of us!
Old Apr 21, 2005 | 08:44 PM
  #69
sb427f-car's Avatar
SSU'S Vice Mod
Cool...I'll definately look you guys up since I'm pretty sure I'll be there. Even if by myself and the digi cam.
Old Apr 23, 2005 | 12:01 PM
  #70
427's Avatar
427
The All Pro heads have factory(15) valve angle and cathedral port also.
My engine has a 4.005 bore and a 3.5 stroke.
The AFR heads we have seen have all been stock replacement type heads. The All Pro heads will have some custom order ability to get pushrod holes moved and rocker and spring pads moved up for performance gains.
Kurt
Old Apr 23, 2005 | 12:32 PM
  #71
sb427f-car's Avatar
SSU'S Vice Mod
Kurt
Gotcha, thanks Kurt
Old Apr 23, 2005 | 09:11 PM
  #72
Anonymous's Avatar
10 second playa
Mike,
Remind me before you go.
I might have to tag along!
Old Apr 23, 2005 | 11:42 PM
  #73
Big Mike's Avatar
Originally Posted by Anonymous
Mike,
No problem! If you want I can pick you up. Let me know...
Old Apr 25, 2005 | 07:47 AM
  #74
NA$TY-TA's Avatar
Kurt
Kurt,
I replied to Kevins PM but i have not heard back from him.... on the All Pro's...
Kyle
Old Apr 25, 2005 | 12:39 PM
  #75
JL ws-6's Avatar
Race your car!
Kurt, could you P.M. me the results of the N/A testing that you did on the Allpro heads? I am researching heads right now for my next wave of improvments, and these are on my list to check out... but I haven't had much luck finding any info.
If possible, please disclose as much as you can about the setup that you tested the heads on, as I want to be able to compare it to other setups that I am also looking at. Thanks a ton!
Old Apr 25, 2005 | 12:58 PM
  #76
427's Avatar
427
The testing we did was for All Pro/ Callies on the unported Hurricane heads. The test was on a 346ci LS1 engine that was stock except for 22x camshaft(mild street grind)and our dyno headers(1 3/4). We ran both a stock unported GM head and a unported All Pro. We also ran a FAST 90mm intake at the end of testing. The test results are available from All Pro.
Kurt
Old Apr 25, 2005 | 05:03 PM
  #77
WS-Sick's Avatar
On the website it says 3/4"+ deck thickness. Does that mean that they can ordered with a specific thickness?
Old Apr 25, 2005 | 05:36 PM
  #78
427's Avatar
427
That refers to 3/4 min thickness. The options are in the rocker pad heights for long valve engines. You can delete some machining like pushrod and rocker stud holes as we like to do on some engines.
Kurt
Old Apr 25, 2005 | 05:49 PM
  #79
Race Car Driver's Avatar
11 & 7 Second Clubs
Originally Posted by RyanJ
if you are not getting W2W to build your FI setup/motor...you're dumb
Futral is actually building my new 347 motor, but it was a tough decision between the two.
Old Apr 25, 2005 | 07:37 PM
  #80
WS-Sick's Avatar
Kurt
Thanks
