Opinion on Hot parts turbo flange
I was debating about making the flange at my work, and making it a little easier on myself since I am fabbing the kit. What do you guys think about a flange with a round hole mating up to a T4 flange. Obviously the round hole will overlap the T4 flange in some spots and cause turbulence. Are their any kits out there that have a round hole in the turbo flange on their hotside pipe (PTK, Pham, TTi)? I know Jordan Musser did it this way, but he never got it dynoed. I just to want to hurt the power potential. I made a quick Pro E model to show what I mean. The yeloow line is the profile of the T4 flange.
That is a bad idea. The collector needs some sort of transition stage before the air hits the turbo. That will create a very in-eficient flow pattern with alot of unwanted restriction and turbulance. Not to mention the area of your, I am assuming 2.5" hole, is smaller then the 2"x3" area of the T-4 pattern. And that is NOT including the blockage you are getting from the overlap.
Why would you want to do that anyway??
most of the t4 flanges out there for sale at turbo places are a 2.5" round hole. I have not experimented back to back to see any possible gains... I have done it both ways though.
Originally Posted by RealQuick
I dont really have room for 5 inches worth of transition from circle to rectangular.
Originally Posted by METAL MAN
You trying to run one 2.5" into the turbo or transition two 2.5" tubes into the turbo? I'll show you how either way if you'd like without doing that hole flange idea?
Whats your idea metalman?
Mightymouse, the opening is only 2.5" circle going into your turbine like i had drawn up? Your making nice power too
Everyone else, thanks for input. I didnt know if anyone would answer this post.
Why don't you get a REAL t4 flange and then form your pipes to that shape instead of a 2.5" circle. Basically your way, you are taking and area of 9.82 square inches, and trying to cram it into a hole with an area of 4.91" . Plus the hole has to flat walls the gasses will hit that will probably bring the hole down to less then 4 square inches!! The turbo should be the smallest point in the system, not the flange before it.
Of course the car will run, but it will not be as efficient as the correct way it was designed for. It will not be much harder to make the 2 pipes merge into the 2"x3" area then it will the 2.5" hole. If you want MAX power, this is the way to go.
