First ATI dyno #'s , need pulley help
carolina auto masters ) 568 HP , 517 TQ , 12.5 A/F @ 5800 rpm . He did not want the car to boost over 9 psi. with the stock bottom end so the limiter is set at 5900 rpm to keep the boost in check . So , with a MMS crank pulley , what size blower pulley would I need to keep 9 psi. at 6700 rpm , or should I just keep this setup a while ? I'm running a 4.0 blower pulley now
carolina auto masters ) 568 HP , 517 TQ , 12.5 A/F @ 5800 rpm . He did not want the car to boost over 9 psi. with the stock bottom end so the limiter is set at 5900 rpm to keep the boost in check . So , with a MMS crank pulley , what size blower pulley would I need to keep 9 psi. at 6700 rpm , or should I just keep this setup a while ? I'm running a 4.0 blower pulley nowJ
carolina auto masters ) 568 HP , 517 TQ , 12.5 A/F @ 5800 rpm . He did not want the car to boost over 9 psi. with the stock bottom end so the limiter is set at 5900 rpm to keep the boost in check . So , with a MMS crank pulley , what size blower pulley would I need to keep 9 psi. at 6700 rpm , or should I just keep this setup a while ? I'm running a 4.0 blower pulley nowLast edited by mzoomora; May 1, 2005 at 06:56 PM.
Kyle
