Help - My bypass valve sounds weird! (Vortech owners)
In reality I wanted to write “my bypass valve is farthing”, but this word doesn’t belong in the thread name
But it’s real: as soon as the manifold pressure goes close to -1PSI (-2 inch Hg) it starts to sound like a horn! This happens only during slow accelerations, if I mash the pedal there is no weird sound.
It’s the Bosch bypass valve supplied in every Vortech kit.
I can imagine that as soon as the pressures before and after the throttle body are the same the rubber membrane starts vibrating
Or is there another explanation?
How can I solve this problem?
Thank you - Stefano
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
Thank you - Stefano
Time for a new one. The Bosch bypass is prone to tearing around the internal rubber diaphragm. The fart noise is air passing through the tear. They are cheap though. You can get them through any VW dealership.
Is it dangerous to drive with the farthing valve? On another forum a guy had his blower broken because of a damaged bypass valve
Under boost it's not leaking and builds up the supposed 6 PSI.
If I go for a different style what brand do you suggest?
Thanks - Stefano
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
Thanks - Stefano
Check out the Vortech mondo. If you want a drop in upgrade, troll around the turbo Audi/VW forums. Those cars also come with the Bosch 110 valve. A lot of those guys are going with Forge motorsports direct replacement valves that are machined aluminum.
I know it's wrong, but the valve really looks like new. What can be different in a new one? Better (stronger) spring?
Is it possible that the hose to the brake boost line makes a difference? Let's say if it's too long/short or wrong diameter? Maybe it's just the distance that induce some kind of resonance... Or also the hoses between the aluminum pipes and the bypass valve?
I'm not trying to save money, but to understand how it works
Buy a new valve. It is making the farting noise because the internal rubber diaphragm is torn, something the bosch valve is notorious for. If I am wrong and the new valve also makes the farting noise, you could always return it to the parts store. Check here for more info http://www.s4biturbo.com/art-dvtests.shtml
However: the valve isn't leaking and works properly and the diaphragm look fine (as much as I can see).
Somewhere I saw that there was an upgraded Bosch valve, mine has those numbers:
040 - 0280 142 102
Any idea?
Vortech racing bypass: you mean the Maxflow od the Mondo valve?
Bosch has an updated version of this valve (#0280142108
). The old part # was 0280142102.
I installed the new one in the original Vortech direction and the farting sound is gone!
The old valve is well known at the Saab forums as "hooter valve" - all clear about the sound.
The new valve has a brass disk with a hard rubber seal (like an O-ring), the old valve has a soft rubber membrane that can vibrate at certain pressure and air flow conditions (HOOT!).
The spring is stronger than the older version. This allows boost at lower RPM, an you can feel it!
Here two links about this subject:
http://www.socalsupras.com/tuning/bypassvalve.html
http://www.quasimotors.com/hooter.htm
