Turbosmart E-boost 2
Old May 10, 2005 | 05:17 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Default Turbosmart E-boost 2
Hey guys we have a test unit coming which should be here by tomm or thurs. I will get some pics of it and let you guys know what I find. We are going to be installing it on a LT1 SS with a 383, running a PTK kit and PTE-88.
Jose
Old May 10, 2005 | 05:29 PM
Tiago's Avatar
woudl that be your SS Jose?
Old May 10, 2005 | 09:08 PM
cablebandit's Avatar
let me test it bitch!!! J/k Jose. Are you going to the gathering? I met you there last year or year before. Tracy dragged me away because we were gettin deep into the car talk
Old May 10, 2005 | 09:30 PM
XLR8NSS's Avatar
Adkoonerstrator
What does this one do above the original?
Old May 10, 2005 | 10:08 PM
ibgoatin's Avatar
Default nice!!
looks pretty cool
Old May 10, 2005 | 10:10 PM
ddnspider's Avatar
whats the price going to be with a GP?
Old May 11, 2005 | 05:54 AM
smokinHawk's Avatar
hey Jose can you set that so it bases the boost per MPH?
or boost per gear at least?
Old May 11, 2005 | 08:47 AM
LS1TECH Sponsor
Here are just some of the features....
*Up to 6 alternate boost mapping functions with specific boost mapping for FWD, RWD, AWD, Bike and Drag racing applications.
*A specifically developed Correction Feature eliminates boost drop-off at high RPM
*Boost levels can now be mapped against TIME or RPM
*Special gate pressure function eliminates wastegate creep
*Peak Hold/Max Boost Recall function monitors the boost and RPM
Old May 11, 2005 | 08:49 AM
LS1TECH Sponsor
Cable, yes I will be at the Gathering if we can get the SS buttoned back up. Its going to be close, darn close. I may just drive it with wires and crap hanging off it...lol
Old May 11, 2005 | 09:45 AM
smokinHawk's Avatar
so no MPH function, just time and rpm.
are there any boost controllers out there that can do it based on MPH?
Old May 12, 2005 | 03:52 AM
CAT3's Avatar
Restricted User
Ok, I have a newb question. How does this controller actually adjust the amount of boost? Are there wires that feed into the BOV (or is WG) and what???? Confused.
Old May 12, 2005 | 07:30 AM
Drewman's Avatar
Just like any other EBC.
The EBC controls a solenoid that determines when the boost reference on your wastegate sees pressure. When pressure builds up to whatever you've asked the EBC to hold, it triggers the solenoid and the wastegate reference sees pressure and opens. The smallest amount of boost you can run is whatever your wastegate spring is set at (minus whatever pressure losses you have along the way, depending on where your reference is set up at).
