spec me out a 347 w/ati
I was just getting to your PM when I spotted this doing a search. See what you think.
As far as 600RWHP on pump gas, I can give you a great example of what we can do. We did a 2004 Z06 that we installed forged flat top pistons, forged connecting rods, stock crank, balanced and blueprinted rotating assembly, 216/224 115 XER cam, stock heads with dual spring kit, stock LS6 intake, stock TB, stock MAF, stock exhaust manifolds, stock catalytic converters & H pipe, stock titanium exhaust and SPEC Stage 3 clutch w/ aluminum flywheel. We installed a front mount single intercooler package, with a P1SC and a Vortech race blow off valve and spun her to make 11-12lbs of boost. Stock fuel system except for a boost-a-pump and 60lb injectors. She put down 606RWHP and 510RWT at a 11.8-12.0 to 1 AF ratio and 22-24* of timing on top. Looks, sounds and drives stock getting 28-30 MPG. A lot of fun snewaking up on folks in the car.
Of course from there you could add headers, off road pipes, better catback, larger D1SC, better heads, larger cam, etc. and get about anything you want.
Talk to you soon and hope this helps.
Mike Norris
