Boost Limit Reached on 10:1 Compression
Old May 20, 2005 | 12:14 PM
  #61
blackz93's Avatar
Originally Posted by Bryan Wilkinson
Perhaps I would have been better to go with a 350CI instead of a 427 with a 3.00 inch stroke.
Do what?!
Old May 20, 2005 | 01:43 PM
  #62
8seclt1's Avatar
what thickness gasket are you running?
Old May 20, 2005 | 05:35 PM
  #63
GTBMad's Avatar
Perhaps that is the key here. Maybe lowering the timimg a couple more degrees, would help the situation. Just remember, You are not running 10:1 and neither is Harlan. That is definately part of the problem here. I have the absolute best parts money can buy from that standpoint. I believe you could run 30psi as long as the Compression Ratio was lowered.
Some sort of cooling is needed. I just dont want to use anything that I have to put in the flow. NOS on the IC, or a C02 pipe on the intake side. I am not seeing any detonation or knock, so I can only assume that cylinder pressure casused the gasket to give way.
according to JE Pistons, They are telling me with a 4.00 inch crank, and 6.125" rods, on a 4.127 diameter cylinder, 9.5:1 is the lowest compression that I can have. If any pistons experts reading this have any other suggestions I am all ears. I am taking JE at their word, but I am also open to options.
If anyone else is reading this, read the specs above before jumping on me.
Thats a suprise you cant get a custom piston to your specs from JE. Wonder if they are trying to shoehorn an existing blank to do the job.
I had a 427 with 4.00 stroke and 6.125 rods
I have since built a 6.0 litre block with the same crank and rods and deck hieght with a CR of less than 8.5:1.
We had a custom dish piston built for this motor, also using SCE Titan series copper gaskets 61 thou thick and the chambers are 72 cc.
They cost me a bomb but it can be done.
Old May 20, 2005 | 09:46 PM
  #64
Bryan Wilkinson's Avatar
Originally Posted by nitrorocket
Bryan, There should really be no difference between a sbc and an ls1 as far as piston in your case. My last 421 had the same bore and stroke as you. When Monty went from 11.25:1 to 8.5:1 compression, he used JE pistons. My point is they HAVE to make them. I would try calling around also.
Wiseco makes a piston!!!
K397A125 has a 32 cc dish! Try that out on your compression calculator!
(PAGE # 8)
http://www.wiseco.com/PDFcatalogs/AB05_chevy.pdf
I think the rep at J.E. was smokin' something. I am sure if you check around, you can even find a larger dish then 32cc with a custom piston.
Nitrorocket, this response is not directed at you, but in a general resonse, by the way..Phone tag, your it.
When I called JE, the salesman, did his basic math, and said they did not make a off the shelf piston for my particular application, that it would have to be custom made. He also stated that the piston would have to go to engineering for final spec.
I am not an engineer by any sort of the imagination, but my feeling here....the same conversation came up with the diamond pistsons that are currently in the car, when I ordered those, Chris @ diamond did not want me to use a 6.125" rod but a 6.100" rod, because with a blown application and the long stroke, he said he wanted a thicker surface for the piston, and to get that the rod had to be shorted so that he did not have to move the wrist pin up into the bottom of the piston. He said it was important to have a certain amount of clearence between the bottom of the piston and the top of the wrist pin. Doing so would have caused the piston surface to be thinner, and my guess is that is a bad deal for a blown application.
When I was talking to JE, the exact same converstation came up, was it a blown app(yes), and was I going to use NOS(no, at least not for power). JE engineering came back and said that the maximum allowable safe CR with my setup which was a 4.00" stroke and 6.125" rod was 9.5:1.
I will try to call again tomorrow.
Old May 20, 2005 | 09:47 PM
  #65
.045 Cometic
Old May 20, 2005 | 09:49 PM
  #66
Originally Posted by blackz93
Do what?!
Forgive me, would not a shorter stroke would allow you to use the same length rod, and have more clearence between te bottom of the pistons deck, and the top of the wrist pin given the same application?
Old May 20, 2005 | 11:04 PM
  #67
nitrorocket's Avatar
Bryan, here is the same physical piston you need. Give JE this job #. This exact piston made 1200 hp on pumpgas and could make alot more. See what they say about that!
JE Custom Forged, SBC400, 18 degree V8
Part Number: 195653
Custom Job Number: 294520
Material: Forged Aluminum 518 D
Bore: 4.125"
Stroke: 4.000"
Rod Length: 6.125"
Dish Depth: .255"
Compression Distance: 1.175"
Compression Ratio: 8.5:1
Valve Pocket Depth: .250", Measured From Deck
Top Ring Groove: .064"
Top Ring Land: .310"
2nd Ring Groove: .064"
2nd Ring Land: .180"
Oil Ring Groove: .218"
Oil Ring Land: .090"
Pin Nomenclature: JE Pro Max Pin
Pin Part Number: JE 92727501793S
Pin Material: Steel Alloy
Pin Diameter: .927"
Pin Length: 2.750"
Pin Retention: Double Spiro Locks
Piston to Cylinder Wall Clearance: .0055"
Measure Clearance: .500" from Bottom of Piston Skirt
Weight (grams) 468
Old May 21, 2005 | 08:10 PM
  #68
Part Number: 195653
Bore: 4.125"
Stroke: 4.000"
Rod Length: 6.125"
Dish Depth: .255"
Pin Diameter: .927"
Pin Length: 2.750"
Weight (grams) 468
I will call them on Monday, and see what they say, left you a message on your answering machine.
Bryan
Old May 22, 2005 | 06:23 PM
  #69
blackz93's Avatar
I'm just curious about the 3.00" stroke?!
Old May 22, 2005 | 07:13 PM
  #70
I was generalizing, about the stroke of the stock motor.
Old May 22, 2005 | 07:28 PM
  #71
Part Number: 195653
Bore: 4.125"
Stroke: 4.000"
Rod Length: 6.125"
Dish Depth: .255"
Pin Diameter: .927"
Pin Length: 2.750"
Weight (grams) 468
I apparently made a mistake,
In reading the order form they sent me it says the following
Displacement 428
Piston Type Dish
Bore 4.127
Stroke 4.00
Rod Length 6.125
Dish Depth .160
Compr Dist 1.109
Comp Ratio 9.3 to 1
Acutal Weight 465.
I am satisfied with 9.3 to 1. I am not sure why I kept thinking it was 9.5
However, the new heads will be able to be opened up to 76cc, so that will get me closer to 9.0.
Old May 23, 2005 | 05:26 PM
  #72
blackz93's Avatar
Oh, ok...I thought you were saying it was three inches even.
