Lt's, True duals's and a turbo?
Old May 19, 2005 | 01:25 PM
lock down's Avatar
Default Lt's, True duals's and a turbo?
I have 01 ws6 is this just wishful thinking or has anyone done this?
Old May 19, 2005 | 01:28 PM
WestSide's Avatar
If you don't want to lose the setup you have now, go supercharged.
You can keep the longtubes if you go with a STS rear-mount turbo kit, but you'll have to ditch the true duals.
If you want a turbo kit under the hood, you're going to lose your longtubes and true duals.
Old May 19, 2005 | 02:35 PM
sb427f-car's Avatar
SSU'S Vice Mod
That's if you go with a single turbo you'd lose the true duals. Concievably you could still run them with a twin turbo set up though.
Old May 19, 2005 | 02:36 PM
onoiocoko's Avatar
true duels could be kept with a twin turbo set up but prolly lose long tubes and still need a custome built kit.
Old May 19, 2005 | 02:40 PM
sb427f-car's Avatar
SSU'S Vice Mod
Definately loosing the LTs and is there anyone making a twins f-car kit right now? I think used CAS' are the only ones that exist.
Old May 19, 2005 | 02:43 PM
WestSide's Avatar
True, someone on here is doing a twin rear-mount setup correct? If you meant twins under the hood...he would have to ditch A/C and power steering most likely. I think a supercharger would fit his needs/wants better.
Old May 19, 2005 | 02:56 PM
ls1charged's Avatar
get a good turbokit like from Phamspeed and then you dont need LT's and can still have true duals if you want.and youll make great power too
Old May 19, 2005 | 08:14 PM
lock down's Avatar
i would like a turbo instead of a supercharger. I guess i could lose the lt's, but would it be worth it to keep the true duals if i go back the shortys?
Old May 19, 2005 | 09:46 PM
WestSide's Avatar
Usually with a turbo the less backpressure the better. You're gonna lose the sound you have now with a turbo, it acts like a muffler.
