procharger ?
Old May 19, 2005 | 08:38 PM
moto-mafia's Avatar
Default procharger ?
Hey guys got my procharger setup installed, fmic , vortec bypass d1s , nice system right at 9 ps1 on stock engine. . . love the set up but def need more power..... iam new to ls1 s and was wondering where do i look for a 408 at? pm me let me know i need a setup just for supercharging , i wana run ALOT more boost..... is the 408 built off my stock block or do they use 6.0 block and heads??? what all do i need to put together a bullit proof 408 and how much psi can i throw at it??? THANKS
Old May 20, 2005 | 11:02 AM
moto-mafia's Avatar
Anyone?
Old May 20, 2005 | 03:21 PM
moto-mafia's Avatar
Help Anyone??
Old May 20, 2005 | 03:25 PM
LSs1Power's Avatar
Check W2W for a 408. I heard they are one of the best in making short blocks. I think u will also need something larger than the P-1SC. Get a F1-R with 408cid and that should be enough for 700-800rwhp. Good luck.
Old May 20, 2005 | 09:27 PM
02SOMWS6's Avatar
SDPC sells a forged 402 for like $3,999. for starters. They are a sponsor here.
Look over here-------------------------------------------------------->
Old May 21, 2005 | 09:05 AM
moto-mafia's Avatar
are the 408s made off a 6.0 block??? what heads should i run ..? i dont have the p1s-c i have the d1s-c
Old May 21, 2005 | 09:11 AM
moto-mafia's Avatar
how many ps1 can you run on a good low compression 408? like the slp shortblock??
Old May 21, 2005 | 10:24 AM
Gary98Z's Avatar
I would guess 10-12 lbs with the d1sc on a 408. You may be able to run more than that, but the d1 will be close to being maxed out, not to mention belt slip issues. The F1 would be a better choice for running high boost in a stroker.
Old May 21, 2005 | 10:29 AM
moto-mafia's Avatar
i have the 8 rib upgrade on my d series , . . . how many psi can i run with a bigger charger on a 408 ? is the slp 408 a good setup for boost
