What supporting mods???
Old May 21, 2005 | 02:54 AM
BottleRocket's Avatar
Default What supporting mods???
I am working on getting my car ready for a turbo. It is going to be a GT45 running 10psi (roughly 610hp) on a cusom intercooled setup. What do i need to get ready? I know I will need injectors, a pump, and a clutch, but I dont know what size I will need of the injectors and pump and I dont know what else I will need. help me make a list
Old May 21, 2005 | 03:26 AM
StoleIt's Avatar
NKAWTG...N
A built engine to safely run 10psi IMO, or a way to lower the CR. What are the details of your engine?
Old May 21, 2005 | 03:29 AM
its stock as of right now. im planning on either: forging the bottom end and putting 6.0L heads on. Or building a stroker with low comp pistons and use LS6 heads. but that is later. I want to be ready for 600hp at 10psi before I do that so I can use the full potential right away
Old May 21, 2005 | 04:22 AM
Wicked_Hugger99's Avatar
u wanting 600flywheel or rear wheel? i'll assume rearwheel
some good heads like TEAs or PRCs. AFRs if cost is no issue
street turbo cam from speed inc 225/225 .581 .581 on a 114lsa if u stay w/ a 346-348 or you can go with a lil of a reverse split. several cams to choose from, thats just my suggestion.
id say mcleod single disc w/ billet steel flywheel or spec 3i w/ same flywheel & maybe beef up the tranny as well. Prolly 42-60lbers and an in-tank 340 or 420, boost-a/f guages etc to keep an eye on things, and def. a BOV since its a 6sp
Might wanna look at one of speed incs complete fuel systems.
a 12-bolt cuz that turbos gonna make some torque!
u'll wanna forged bottom end eventually
hmmm..........just a few things i think u might wanna get
just my .02cents
Old May 21, 2005 | 05:06 AM
the kit comes with the BOV
I know i dont need H/C to make it to 600hp. The test car this kit was put on was a stock motor (except for forged pistons/rods) and with a good tune it made 612rwhp at 10psi. what you listed there seems like im shooting for 800hp, not 600.
Old May 21, 2005 | 05:10 AM
stock heads/cam and it made 612rwhp@10psi? who did this?
Old May 21, 2005 | 05:21 AM
a guy that I know that started making 3.8L kits and now is making LS1 and LT1 kits. I cant post a link, hes not a sponsor
Old May 21, 2005 | 05:47 AM
I was thinking:
Spec Stage 3
12 bolt or 9"
60lb injectors
420 in tank
ARP studs
and probably a driveshaft in the near future.
Old May 21, 2005 | 07:28 AM
SS00Blue's Avatar
Um, have you looked at the compressor map for the GT45? At 1.68 pressure ratio, you're not even on the map. You should probably consider either raising the boost to 20 pounds or so, or maybe consider another turbo.
SC-
Old May 21, 2005 | 11:48 AM
can you PM me the link. I really wanna check this thing out! thanks man.
Old May 21, 2005 | 12:42 PM
ABeasst's Avatar
I know the guy I'll PM you
Old May 21, 2005 | 12:49 PM
force-fed-fabrications.com
Old May 21, 2005 | 01:57 PM
ABeasst's Avatar
yea I PM'd hi
