max boost or rwhp on LS2 block?
Old May 26, 2005 | 12:26 AM
dirtracer's Avatar
Default max boost or rwhp on LS2 block?
Im building my twin turbo ls2 right now and i was just curious on how much hp these ls2 blocks can hold in them without grenading. Here is some info on my setup: Scoggin dickey bottom end, calies crank, rods, JE pistons, hell fire rings, cometic .40 gaskets, afr 225's, fast intake, nick williams 90mm, arp studs, and a set of custom turbonetics ball bearing turbos.
Whats the most hp some of you guys are running through the ls1/2 block?...ive never really heard of these block comming apart, but i just wanted to be sure before i get carried away with the boost button
Old May 26, 2005 | 02:07 AM
99SS-T's Avatar
From what ive heard 750 is pushing it with out a girdle on the bottom end. Alot of flex in teh aluminum blocks. Ive heard of them getting so distorted under boost that they seperate from the heals enough to leak while under load. The bottom end girdles seem to make it possible to run alot mroe power in the LS1's and i would imagine the LS2's. GL man
John
Old May 26, 2005 | 02:51 AM
redaddiction's Avatar
Who sells the girdles ?
Old May 26, 2005 | 03:43 AM
Nate_Taufer's Avatar
do a search on ebay. I think the guy who makes em sells em on ebay for around 400 a pop.
Nate
Old May 26, 2005 | 03:53 AM
Wicked_Hugger99's Avatar
i believe W2W sells them because Kurt has posted on here before about them
"Our girdle is .750 thick at the mains and about .550 at the oilpan rails. Ours is made of aluminum, the one from 274 is SS so could be much thinner and still have great holding power.
I have one of our girdles on a stock cap that will see some boost before the end of the summer, after dyno we will disassemble and inspect mains.
Kurt"
that was his post so i assume they have them
www.W2Wpowertrain.com
i tried a link to the ones on ebay but it said they were removed
Old May 26, 2005 | 10:10 AM
dirtracer's Avatar
very good info on that girdle. I never heard about that yet. im gonna make a few phone calls and pick one up. thanks. anyone else? there has to be some aluminum block guys in here running some big power through them?
Old May 26, 2005 | 10:16 AM
99SS-T's Avatar
Dont you worry keep this on the first page adn you will draw the big boys attention. MightyMouse will be able to help ya out. GL mate
John
Old May 26, 2005 | 10:42 AM
smokinHawk's Avatar
i know kut has put a few girdles on some iron blocks he did.
i believe he has to machine the block to get them to fit properly.
alot of them have seen over 1500hp
Old May 26, 2005 | 11:31 PM
dirtracer's Avatar
ive got one of those girdles and custom arp main studs coming from DM performance. Demetry was easy and informatable work with. The thing looks pretty trick. Thanks for the hookup!
Old May 26, 2005 | 11:32 PM
dirtracer's Avatar
anyone else?
runnin some big boosted power through an aluminum block?
Old Jun 1, 2005 | 11:09 AM
dirtracer's Avatar
O.K.,
i just noticed that i for got to mention in my post at im building a ls2 "402" stroker. Will this girdle clear the crank?
Old Jun 1, 2005 | 11:44 AM
Z06PSI's Avatar
It is supposed to. I am also getting a girdle but only for a 347....
Old Jun 1, 2005 | 12:14 PM
y2khawk's Avatar
never ran a girdle, never had any block problems. Well, atleast not after i put in the motor plates
