Wanting A Pro-Charger
Old Jun 3, 2005 | 07:07 PM
98BlueTansAm's Avatar
Question Wanting A Pro-Charger
Well, i have a 98 Trans Am . It's slightly modded to put it at around 400 rwh . I'm wanting to put a procharger on my car, but don't know what all is going to need replacing and upgrading . I have a $5,000-$8,000 budget for this, and don't want to go over this price. I am looking for any suggestions, as well as help on saving a few bucks. Also (off topic), I'm looking for a set of true duals that come completly to the back w/ tips. Lastly, Any cheap mods anyone knows of would gladly be appreciated as well.
Old Jun 3, 2005 | 07:15 PM
Chas1's Avatar
You can get the P1SC1 (5#)installed with guages and a tune for about 7k. If you want more boost you will need to change injectors.
Old Jun 3, 2005 | 07:43 PM
2000 Tran Zam's Avatar
how much power are you looking to make? anything more then 550 rwhp might be pushing it on stock bottom end, unless you have a killer tune.
good luck though.
Old Jun 3, 2005 | 07:59 PM
UtOhCop's Avatar
Be careful. Prochargers always seem to have belt slip
Old Jun 3, 2005 | 08:27 PM
Ed Blown Vert's Avatar
Just get the SDCE tensioner.
Old Jun 3, 2005 | 09:32 PM
UtOhCop's Avatar
SDPC and SLP has a 402cid Short Block for 4K.
Add some nice Heads, LS2 Intake and a lump cam and watch out.
Old Jun 3, 2005 | 09:49 PM
Third Gear's Avatar
Procharger
Old Jun 3, 2005 | 11:20 PM
2001whiteSS's Avatar
i'm thinking of getting one as well. how much would it cost for just the procharger and all the parts. I have a buddy that says he can install it, he has a shop and everything(tools). how long does an install usually take?
also will a procharger fit under a stock SS hood? and will a borla catback be good enough exhaust?
Old Jun 3, 2005 | 11:27 PM
Blown SS's Avatar
Keep your eyes peeled for a used setup , that's where I got mine .Lot of guys going turbo , making them easier to find . Procharger does fit under my SS hood , just barely touches . I also have a borla catback and it works well , Good Luck
Install took myself and a friend with air-tools 14 hours. Wasn't to hard at all.
Yes it will fit. And no cutting of the oil pan. I run a Borla.
Old Jun 3, 2005 | 11:29 PM
Your running the same injectors and FP as I. What does your fuel pressure drop to @ WOT?
Old Jun 3, 2005 | 11:32 PM
Blown SS's Avatar
Around 45 , pretty lean up top ( meth. kit on the way to fix that )
Old Jun 3, 2005 | 11:34 PM
thanks for the quick reply guys.
so the procharger doesn't take oil from your engine? is it self contained?
also, did you guys running the procharger with the borla get a larger y pipe?
Old Jun 3, 2005 | 11:36 PM
Blown SS's Avatar
Exactly
Old Jun 3, 2005 | 11:38 PM
awesome, and we are looking at how much hp gain? and as far as $$, is it realistic(with self install, friend and me) doing it for under 4k?
Old Jun 3, 2005 | 11:42 PM
Blown SS's Avatar
As long as you keep the boost low, and you can find a used kit , it would be close to that $ . Up the boost .............up the $$$$$$$$$$$$$$$$
Old Jun 4, 2005 | 12:17 AM
KissMySSo1's Avatar
Wastegate doesn't have belt slip
Old Jun 4, 2005 | 12:29 AM
Oh, I thought I had a problem. Mine dropped to 40# Thanks.
Old Jun 4, 2005 | 12:30 AM
Yes self-contained.
I am running Jet-Hot Headers and their Y pipe. Exhaust is important on FI.
Old Jun 4, 2005 | 01:17 AM
Rick@Synergy's Avatar
We sell a full Race Supercahrger kit that uses the ATI head units with the SDCE tensionor. PM me for more details if you like.
Rick
