Induction Suggestions
After I get those answered I would like some suggestions on where to look for the products. I'm wanting to keep it pretty cheap. Proably around 5k-7k. It would be nice if I could get more than 400HP at the wheels.
Let me know what you all think.
as far as looking into something else, like i said, it depends on what your budget is, what your power goals are, and if you are able to fab something up or buy a complete kit.
if you have a 6 speed, you will definately need to upgrade the clutch, highly recommended to upgrade to a 12 bolt(unless you dont plan on launching hard), some suspension stuff like subframes to stiffen up the chassis(dont want it flexing a lot under load), fuel stuff(bigger inj's, possibly 255 lph walbro fuel pump, maybe a fuel pressure regulator depending on what the installer says you need.) and other things here and there.
now its not all 100% necessary, however expect to be limited as to what you can do. some system come with everything you need in regards to fuel, mounting brackets, etc...
speak with a vendor such as Exotic performance plus(i hear they have good supercharger specials) or phamspeed or tti makes some decent turbo kits.
also depends on if you want AC or not too. i took my setup to (and recommend) futral motorsports, their quality of work is superb, however it takes forever to get it done since they are so backed up.
good luck with everything, do some research, and talk to those sponsors.
With that little of a budget, I don't see how you will put a turbo or supercharger on the car. 400 hp at wheels will be a little tuff for heads cams at 5800 ft altitude, but not impossible. Depends on if you want to be able to pass emissions. A turbo won't pass a visual inspection, although a sts should be able to get a EO no problem. Several supercharger kits have EOs.
Gary
Most I ever dyno'ed is with my Procharger with cog set up and that lasted but a few seconds due to injectors running out, 498rwhp. I've gone turbocharged now....we will see.
STS would be my first choice, reason being emissions testing here in albuquerque. Not really too tough as all you have to do is pass a visual and a PCM scan for codes. I've been able to squeek by even though the car has gotten further and further away from being emissions legal. Two years ago, I paid to get passed
I might have to do that again this year
J
J
J
Gary
A) blow up your motor
B) get a forged motor
C) A&B
Gary, no joke...we have to practically sell our souls to get heads and cam power that the sea level guys enjoy...and we are FI'ed!!!!
J
<--guy was there
As far as the dyno and track....lets just say i'm getting closer with every trip to work...tuning sucks.
J
I've been reading about 50 threads and hundreds of posts without any answers to these kinds of questions. Can anyone help me out?
