anything wrong with this oil return?
Old Jun 17, 2005 | 04:56 PM
StoleIt's Avatar
NKAWTG...N
Default anything wrong with this oil return?
think that will work? i dont want to thread it in much more, its already in there a bunch so dont worry about it falling out or anything. im just wondering if thats okay since it kinda goes down a little then goes back into the pan. thanks!
Old Jun 17, 2005 | 05:04 PM
ABeasst's Avatar
unless you have a pump it wont work. If thats a gravity drain then the oil wont get back into the pan and the return will fill up with oil.
Old Jun 17, 2005 | 05:05 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
No it will not work without a pump.
Old Jun 17, 2005 | 05:51 PM
99SS-T's Avatar
I hate to see posts like this. Really sux that ya didnt ask around first. I hopd ya have better luck man!!!
John
Tiago's Avatar
not enough angle
Old Jun 17, 2005 | 07:17 PM
StoleIt's Avatar
NKAWTG...N
what can i do besides getting a pump to get that to work? only curious because the oil to the turbo is coming from over the valve covers, so i figured that would be enough pressure to get the oil up and over.
Old Jun 17, 2005 | 07:30 PM
Tiago's Avatar
raise the turbo
Old Jun 17, 2005 | 07:36 PM
StoleIt's Avatar
NKAWTG...N
Originally Posted by Tiago
raise the turbo
i cant raise the turbo. its stuck to the log which is stuck to the block. what i dont get is because thats exactly what the directions in the TTi kit said to do.
that picture is directly out of the instructions. if i screwed that 90 degree bend in more would that help?
Old Jun 17, 2005 | 08:08 PM
frcefed98's Avatar
*EDIT*
I just looked at some pics on mightymouses site and his is in the same spot. Guess you'll be OK. I'd PM mightymouse if you have any other questions on the TTi kit.
J
Old Jun 17, 2005 | 08:40 PM
libertine1015's Avatar
Its better on the side of the pan, check out smokinhawks website. He has pics.
Old Jun 17, 2005 | 09:47 PM
StoleIt's Avatar
NKAWTG...N
ya sadly i know about the side thing already, i just cant pull my engine to get to it. so im stuck with what i got.
Old Jun 18, 2005 | 01:25 AM
99SS-T's Avatar
I dunno man. When im thinkin about it, it seems like that will cause problems. Alot of the time there is positive crankcase pressure, which even if it is a little I would imagine it would really restrict the amt of oil that makes back it into the pan. I hope it works out man.
John
Old Jun 18, 2005 | 04:09 AM
StoleIt's Avatar
NKAWTG...N
ditto
Old Jun 18, 2005 | 10:06 AM
MIGHTYMOUSE's Avatar
it will be fine, good job on the install.
Old Jun 18, 2005 | 11:22 AM
SINISTER's Avatar
x2 Many have ran it that way for years
i personally would of gone to the side but that will do you just fine
Old Jun 21, 2005 | 05:25 AM
SStolen's Avatar
Worked on my kit for a year now.
Old Jun 21, 2005 | 07:26 AM
smokinHawk's Avatar
i had that on mine for a while, it worked, but not great, just get used to your car smoking some.
the main problem with that is the fitting sticks up in the pan some, raising the return point how ever far the fitting is tapped into it.
also you might switch to some braded line or even high quaility silicon hose, as if that ever heats up or devolops a hole, your done
