6.68 @ 104 1/8 at 3200' DA yesterday
Decided to hit a local 1/8 mile track yesterday and make a few blasts. It was fairly warm and humid abd the BARO was only 29.8 but it still ran pretty decent. Best 60' was a 1.544 and I think the little 8.6" wide ET streets are about at their limit. Still on the '01 Z06cam, stock valves in ported 98 heads, 98pcm/MAF, stock connecting rods (ARP bolts), wiseco pistons (9.5:1 compression). I am happy with the MPH at this track in this weather, ETs are a little off due to some tirespin.
Thats the good.
I am seeing very high IATs though, over 30 degree rise on a 1/8 mile pass, a good 55-60 degrees over ambient when I let off, around 145 degrees. That plus having the car on the dyno the other day and having a A&A car to compare it to I will say this 3" OBX just isnt up to the job. I was only showing a little over 11psi at 6600 rpm.
I think I am going to try to have Griffin make me an intercooler about the same dimensions with a 4" or so core and see what happens. The A&A kits I have worked with have never seen IATs like this and they use a Bell IC I believe. I may be throwing money away on a different IC but I'm pretty sure this one just isnt cutting it, done enough of these cars by now. I dynod right at 520rwhp with the TH400/9" and slicks so its not making a ton of power but this IC might just be too small.
here is a vid of a 6.80 pass, I couldnt hear my car with the mustang next to me and whacked the limiter pretty hard on the 1-2 and of course the only vid my wife took was the worst pass of the day, at least I beat the mustang though
Ran 6.68, 6.69, 6.74 and 6.78 also, between 103.1 and 104.1.
![](http://thumbs.streetfire.net/CECBDBD9-4D0B-4286-A66C-27890C058C98.jpg)
Click here to see Video
PS: I'm just trying to kill these tires and thats why the John Force burnouts, these things just wont wear out and I wont throw them away until they are used up
Thats the good.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I think this flows OK, I just dont think it can handle the amount of air going through it. I should just take it off and run a pipe across and see where the boost is at. If I dumped the IC and ran meth I would lose 40lbs off the front probably and pick up 4psi with a straight shot right to the TB
hmmm, video is real choppy
It would be interesting to see the results from your intercooler test, even with just the meth.
Damn I love black WS6's, looks saweet!
LS1TECH Sponsor
The OBX units are not meant for high performance apps. We had a customer of ours that had the same heat rising issues as well. The IC is not very well designed. A temp. solution is , flip one of the tanks over, that dropped the IC temps down about 25 degs.
JZ
JZ
JZ
JZ
I have used some ICs woth the inlet/outlet lined up (spearco) on other turbo cars and I never seen anything like this. Maybe this core is aluminized steel or something - it sure weighs enough
toslowtosay, I was using 1/2 93 and 1/2 104 unleaded, it wouldnt do too well on straight 93 with these IATs. Going to a dragstrip on pump gas alone in 85+ degree weather with 9.5:1 compression and 10+ psi is asking for trouble., mine may run OK on 93 but why take a chance for 10.00 in gas.
i used a 3" obx with 700hp and on several back to back wot my iats never went over 90...the obx works just fine for some of us. I will be putting a 4" obx on a t88 408 setup soon as well...I will keep an eye out for similiar issues you had...it would suck if I got heat issues too but so far i was lucky with the last one.
Also there is a huge difference between driving down the highway and making a blast with the whole front of the car being cooled off and going to a dragstrip with your car baking in the 85+ degree sun, doing a burnout and letting it stage. I'm starting at 105-115 on the starting line on a 85 degree air temp day so adding another 30-40 degrees on a pass and thats getting up there in temps.
I'm not saying this OBX is no good, it works OK and to be fair they only rate it at 600bhp which I am over anyhow.
Here is a couple logs from the dyno a few days ago with the curser on the max temp (pic 1 and 2), first pull was 520, let it slow down and the second pull was 470, let it cool off for 15 minutes and it was at 515 again (IAt was the same as the first pull). Also another log (pic 3) of an 1/8 mile pass from friday, starting IAT was 109 and it was 85 out, dont mind the speedo, its hooked to the front wheel sensor and is 20% off, never got around to fixing it yet..
Maybe I'm just expecting too much out of a smallish air to air at the dragstrip, but I am just comparing this to dozens of logs I have from D1 A&A C5s and a couple twin turbo cars with Bell/Spearco ICs and mine are a bunch higher in similar conditions.
Also, thanks forcefed98 for noticing the giant air leak on my car in the video. I never really paid attention to it but he said it sounded like the bypass leaking so I watched the video a couple times and it sure did. Turns out the vortech mondo uses and O-ring to seal it and it blew off and was laying around the shaft. Fixed it today and picked up about 1/2PSI, thats 10hp so what the heck
I have a feeling that o-ring blowing off is somewwhat common by the looks of how its made.
great info kp, i notcied in your efi lives that the two hot iat's the car was 196 an 210 but when the car was 172 it was 90 on the iat. Are you sucking in too much engine temp as well?
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I can even hear it bypassing while you are burning out....very distinct sound the MONDO makes. It should've only made its loud *** pSSSSSSSSHHH when you let off in the burnout box. Then when you went by the camera it was clearly the MONDO blowing your HP away.
Hope you can fix it with a new oring and maybe some glue in that groove you were telling me about.
J
Originally Posted by Slowhawk
In this weather lately any intercooler will suck
You will see higher intake temps and decrease in boost.Bring back a 40degree day and you'll gain 80-100hp ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
PurEvl, My intercooler is nowhere near the radiator and neither is the IAT sensor so engine temp really shouldnt affect the IAT at the sensor, matter of fact my fastest 1/4 mile pass to date was coming right around after a pass and the ECT was 210 degrees. The IAt went from 89 (76 degree evening) to 127 at the end of the 1/4, where a couple cars I have logged with bigger coolers would only pick up 20 degrees at similar power levels. 38 degree rise is a lot on a 76 degree evening with only 11-12psi IMO. Dont mind the weird log jumping around, OBD cable was loose but here is that pass.
Anyhow, I'm not bashing on the OBX or trying to sell anyone on another brand, its working decent but I think I can do a little better with a little larger core from what I have observe/logged on the dyno and track with similar cars with different IC configs. Like I said the 3" OBX is only rated for 600 at the flywheel, I can t expect it to do any better. My main decision right now is to either have Griffin make me a cooler and redo the piping, or try a 4" OBX and just slap it right in. Honestly I am not going to push this thing much harder (stock connecting rods) then I am so I dont need a mega cooler, but if I could knock off 5-10 degrees of temp rise on a 1/4 mile pass on a 80 degree day for a few hundred bucks I would be happy, dont think thats asking a whole bunch
Its pretty clean inside, like I said though if its rated at 600bhp and I'm making 600 at the wheels (if I had an M6) it would seem to me I'm exceeding its limits a bit
Honestly its a well made cooler and its hard to beat for the $$ no doubt. I may just try the 4" OBX since after coating all the piping, making nice little panels under the front to seal the IC to the big hole in the front and make everything and look nice I just dont feel like tearing it all apart again and starting over ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I brought this car home and it was stock on march 6th so I think I can take a little break from working on it for a while, I need to work on the 60's a little more then I need another 20rwhp right now
Oh well, didnt really want to invest too much more time or money into this setup since it has already done what I wanted it to do and its pretty much free waiting for cooler weather ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But I ordered a 4" OBX since it will pretty much be a direct swap, we'll see what happens and it sure cant hurt. I may leave the front off and swap them right on the dyno and even put a thermocouple in the inlet since EFIlive has a direct K-type input and will log. Would be interesting to see the in/out temps.
