Thinking Question.?
Old Jun 30, 2005 | 02:39 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Default Thinking Question.?
If I can put 150wet kit on a car, with no other mods, and run fine.... Why does the turbo require some retard at the same power level... The reason for the question of corse is the truck project.
Ricky
Old Jun 30, 2005 | 02:49 PM
Brains's Avatar
Because you've increased the dynamic compression ratio with boost, added some heat, etc.
The cylinder pressure prior to ignition is much lower with a nitrous motor, which means less need to retard the timing to avoid pre-ignition.
Old Jun 30, 2005 | 03:04 PM
99SS-T's Avatar
Game, Set, Match.
John
Old Jun 30, 2005 | 04:01 PM
NXRICKY's Avatar
You sure.lol So if you cool the air with water/meth your good to go.
Ricky
Old Jun 30, 2005 | 08:25 PM
Brains's Avatar
**** I dunno, I'm just guessing
Old Jun 30, 2005 | 08:39 PM
menlatin's Avatar
actually yes. As long as you're reasonable with the compression and boost you can probably run boost and meth with no pulled timing.
Old Jun 30, 2005 | 10:24 PM
NXRICKY's Avatar
hey watch those strong comments. LOL. Sh T sounded good to me.. Guess I will be the huckelberry and find out, its only an engine what could go wrong.
Find out real soon.
Ricky
Old Jun 30, 2005 | 10:35 PM
Brains's Avatar
Didn't say it wasn't an educated guess though
You'll be alright man.... I think...
