Turbo LS1 Nova construction pics
check out pics here.
http://www.geocities.com/nova442.geo/turbonova.html
does anything look out of place or handicapping it somehow?
theres another page my buddy made it should work.
Intercooler is in a tight spot. the corners are all notched and the squared looking radius is there cause the grill is so close. the area and volume is still all there. once i get it all cleaned up and the grill back in place i'll post a pic.
As of engine management, I plan on using the stock f-body PCM for now and see how it works.
Right now i just have a 5.3 shortblock with a set of ported 6.0 heads on it.
this is just an "experimental" shortblock, once i get it all tuned and running decent i plan on building a shortblock for it. Im kinda building it backwards, im building the turbo setup i want, then the engine that can handle it after.
Other than that i would say you are doing a superb job on the fabrication end. What are you using for engine management? BS3? Megasquirt? Something else?
