anyone here have 1/2" head and main studs?
Old Jul 13, 2005 | 11:08 AM
Paulz2820's Avatar
Default anyone here have 1/2" head and main studs?
just wondering what the standard ARP 7/16 studs will take compared to the 1/2 studs. i'm goin for over 1200hp on race fuel with the 6.0l iron block. also how much did this cost you at the machine shop and what machine shop did you use. what equipment should i look for to make sure its done correctly. i'm in NC/SC. thanks.
Old Jul 13, 2005 | 11:20 AM
disassembled's Avatar
I would ask around at the big HP guys (1300+ HP) such as W2W and HPE(the only two i know of off hand). If you want a motor built to withstand the HP levels you are talking about then these should be top on your list as they both are well rounded in this territory. HPE is building my 398 6.0 block to withstand 1500 hp. The short block was priced around $4500. Long block(fully ported 6.0 heads with farrea super alloy valves), jesel rockers, and morel lifters puts me at around $7600. The heads were pretty cheap so i would factor in a bit more for those. Also i have a set of 6.0 heads for sale if you're interested.
Greg
Old Jul 13, 2005 | 11:44 AM
smokinHawk's Avatar
only guy i know of with 1/2" head studs is Stealth (or something like that)
he had a 400+ iron bolock with a votech super charger.
i think he sold the car or parted it out.
he was one of the first to be making over 1000rwhp
Old Jul 13, 2005 | 11:57 AM
Paulz2820's Avatar
well i'm building the motor myself i just need the machine work done. its going to be a 375-380ci motor with STOCK afr225. i just need to know where ya''ll got the machine work done.
Old Jul 13, 2005 | 11:59 AM
hellbents10's Avatar
LS1Tech Sponsor
What does Kurt have on the engine in Casper? That motor made nearly 1600hp right? It was something like a 352ci alluminum block.
Old Jul 13, 2005 | 01:40 PM
smokinHawk's Avatar
i think just the l19 head studs. could be wroung though
Old Jul 13, 2005 | 04:01 PM
427's Avatar
427
We use a 1/2 head stud with a std 11mm main stud. Casper has a arp main stud that is longer to pass thru our girdle system that we use on high hp engines.
Kurt
Old Jul 14, 2005 | 07:17 AM
Paulz2820's Avatar
thanks i'll be using the girdle too. do you think the aluminum block will take 1500hp as well as the iron? or is that iffy?
Old Jul 14, 2005 | 08:17 AM
427's Avatar
427
We have not tried high hp aluminum blocks yet. The LS2 block has many improvements that will help in the high hp engines. I would use a LS2 block to exceed 1500hp.
Kurt
Old Jul 14, 2005 | 09:07 AM
Phate's Avatar
The head studs on my motor are 9/16.
