compression? 6.0 Heads on 5.7 block
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
Others say the head is a 71.24cc which would give you 9.52:1 CR.
Now if you use a .060 gasket you would get
72cc = 9.32
71.24 = 9.4
72cc = 9.32
71.24 = 9.4
Dont go with a thicker head gasket to drop compression..... that is not the way to do it.......why risk blowing a head gasket.
Most stock 6.0L heads are a 71.2cc's so with them you will be right around 9.5:1.... like others have said.
Kyle
Kyle
I agree, but I believe the 6.0 Trucks use a .060 gasket so that is why I threw those numbers in there.
https://ls1tech.com/forums/showthread.php?t=111207
