FI and after market fans
Old Jul 17, 2005 | 05:07 PM
HellRaiser's Avatar
Default FI and after market fans
Ok I go the IFR good( well I think) The car idles real nice now. I put a set of flex-a-lite fans in and they won't turn on. They came wire together so I left them like that and wired them into the one facorty wire harness. The longer one, I think it ran to the passenger side fan. IS this wrong?
Also the car idles great but if you give it a little gas it bogs bad. What can I do to fix that?
Old Jul 17, 2005 | 08:07 PM
HellRaiser's Avatar
So I am the only one here that put after market fans in their car?
Old Jul 17, 2005 | 08:21 PM
69firebird's Avatar
yeah apparently
Old Jul 18, 2005 | 12:23 AM
Armageddon's Avatar
...with cheese.
If I'm not mistaken the factory fans have seperate power. Meaning a power and ground for each fan. I got the two seperate fans and wired them up with the factory wiring... worked like a charm. Good luck!
Old Jul 18, 2005 | 12:25 AM
y2khawk's Avatar
on the fans, the factory ones are wired in series for low speed. If you tied into only one fan plug and left the other one hanging, you have an open circuit when they try to come on.
I'm not 100% positive without looking at my notes, but you wanna tap the black and blue wires that go to the fans. That should turn your fan on when the PCM calls for low speed fans.
Old Jul 18, 2005 | 12:37 AM
NA$TY-TA's Avatar
Matt is right the blue and white wire are what worked for me when i had a single fan on my Procharger setup. Be sure to wire them the correct way ...... i wired them backwards at first and they were blowing hot air from the engine into the radiator...... car was over heating till i switched them.....
Kyle
Old Jul 18, 2005 | 04:49 AM
HellRaiser's Avatar
Thanks guys. frcefed98 said the same thing in a pm. I will fix it today see what happens,
Old Jul 18, 2005 | 02:05 PM
frcefed98's Avatar
calm and easy bro, i'll always help you out. Gots to check your pm's first.
J
Old Jul 18, 2005 | 08:36 PM
HellRaiser's Avatar
Got it fixed today. Thanks for your help guys.
Now I got SmokinHawks tune into my car right now I just changed the IFR for my 60#'s(he has 42#) Car seems to run real smooth. I did this just to get the car running, kinda break in the new clutch and make sure the setup is working alright. Then I plan on taking it to someone (maybe RAPID MOTORSPORTS). You think I'll be alright with this? His tune was for 10psi, low timing and stuff. I don't plan on really getting into boost untill its tuned. Is there anything else besides the IFR I should change?
Now for the bad part. The turbo is getting to much oil. So I have to do what frcefed98 did and get a restricter for the feed line. I look like Cheech and Chong going down the street.
Old Jul 18, 2005 | 09:18 PM
frcefed98's Avatar
Cop pulls em over, sez- excuse me sir, can I see your license? Cheech- isn't on the back of the car man
Ok Ok, PM'ed you on the restrictor thing.
You'll be fine with that tune, just keep your foot out of it until you can make it down to mikey.
J
Old Jul 18, 2005 | 10:31 PM
99SS-T's Avatar
Dammit get that thing on the dyno adn break it already. lol GL man
John
Old Jul 19, 2005 | 05:16 AM
HellRaiser's Avatar
Soon.... I am selling my GMMG exhaust right now and plan on useing that money for the tune... If anyone wants a GMMG exhaust with maybe 50 miles on let me know. Its going for 100 below what the GP is selling for. But you have to pick it up.
