STS guys, or anyone! Low Low voltage???
But after that the voltage drops way below 13 and gets into the red especially at idle. I have a brand new redtop Optima and a brand new alternator which have both been checked and re-checked again to make sure they're good. If I don't keep the rpm's goin I start losing spark and then missfiring. Before the new motor I had the sts kit for a few months and never had any problems, but now I do. I have checked ALLL the grounds and negative wires to the block, heads and frame and they're all good. Anyone out there have any ideas? Anything will help, it sux havin a new forged 370 you can't drive. Thanks (and if there's a better forum to take this, tell me)
The bigger cubes and heat from the hot side of the turbo kit could be heat soaking the regulator and still allow the alternator itself to pass the test.
The quick check would be to put the old alternator back on (if you didn't replace it from a previous failure) and see how it looks.
Rick
Todd
