Fi Cam
Old Jul 22, 2005 | 11:13 AM
Ed Blown Vert's Avatar
After hearing some of this maybe I should go with something like
222/226 .563/.569 114 LSA
God I hate this Decisions Decisions............
Old Jul 22, 2005 | 11:14 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Who do you plan to order the cam from?
Old Jul 22, 2005 | 11:38 AM
From my engine builder. It will be a custom cam.
Old Jul 22, 2005 | 02:27 PM
LS1Tech Co-Founder
Who does he buy them from?
Old Jul 22, 2005 | 03:33 PM
I think it was Cam Motion?
Old Jul 22, 2005 | 03:41 PM
MIGHTYMOUSE's Avatar
i'm pretty sure that next time my motor is out the cam will be going smaller, maybe back to stock again.. it ran really good with that one
Old Jul 22, 2005 | 03:47 PM
Got Me SOM's Avatar
I guess you should decide if you want more midrange power or more high end power that'll determine which cam will be better suited to your needs.
I'm running a more aggressive cam but I think it will work out nice for my needs. (224/230)
Old Jul 22, 2005 | 04:00 PM
I already know I want more power under the curve.
Mightymouse, what small cam did you run?
Old Jul 22, 2005 | 04:06 PM
stock 98 cam and 98 ARE s2 heads were on board for my best pass to date (last august) motor was also stock cid then.
Old Jul 22, 2005 | 04:23 PM
Interesting. You would think something a bit larger than stock would be better.
Old Jul 22, 2005 | 04:26 PM
well it certainly could be.. but you have to have everything else around it right to make it work.. and i havent had a clean pass all year.
Old Jul 22, 2005 | 04:28 PM
  #32
True that, thats why I am asking questions. Trying to do right the first time.
haha, a bad pass for you is a good one for me
Old Jul 22, 2005 | 04:50 PM
  #33
Slowhawk's Avatar
LS1Tech Sponsor
Define midrange? You mean area under the curve? A smaller cam with that LSA might have really good peak HP but wouldn't you agree that it's not necessarily, or probably not, going to have as much area under the curve? If I try to extend out what I think you are saying, then are you saying that a 220/224/115 would make more power than 230/236//115 or a 236/246//114? I would not agree with that. I'm sure I am missing something.
FWIW my 230/236/115 idled great and it did not sound that big. The current 236/246//114 is very very lopey.
Change your Cam to a much smaller one and you'll see what I mean I was extremely surprised with the result's.If I find the dyno graph I'll post what a 220 Cam can do
Old Jul 22, 2005 | 04:56 PM
  #34
Slowhawk's Avatar
LS1Tech Sponsor
Here is the graph.
built 346
AFR 205 heads out of the box.
220/224 Cam
D1 at 14lbs
93 octain pump gas
Kooks headers
M6
97 Vette
The first pull of the street tune was 720hp at 6000rpm but I detuned it as far as possible for the customer to get use to it --12 degree's of timing -in this graph
Old Jul 23, 2005 | 08:24 PM
  #35
Bad30th's Avatar
You want something REEEEEAL small Ed !!
Just kiddin', I think you're on the right track with the 222/226 .563/.569 114 LSA, or maybe 115 LSA.
The extra cubes should make that cam pass smog no problem. BTW, my cam is a Cam Motion cam (still using the 222/224 .571"/.571" 114).
Rob (Bad30th)
Old Jul 23, 2005 | 09:02 PM
  #36
longrange4u's Avatar
I personaly like the LPE GT7 cam.... almost stock idle
Old Jul 23, 2005 | 09:33 PM
  #37
LS1Tech Co-Founder
Call up Terry @ Cam Motion, and talk to him about it, and then have your guy order the cam.
Old Jul 23, 2005 | 09:37 PM
  #38
ddnspider's Avatar
Thats the thing with his and my motors...we have a 383 not a 346 so i would imagine if a small cam would work really well then a slightly larger cam would do the same thing in a bigger motor....
Old Jul 23, 2005 | 10:51 PM
  #39
LS1Tech Co-Founder
Have folks passed with 224//230 cams?
Old Jul 23, 2005 | 11:07 PM
  #40
Inspector12's Avatar
TT-TECH Veteran
I have past alot of peple in my area LOL! I make more power than in my signature and it has great driavblity and I am 346/7 CI. I am on a 114 though.
