Why Not To Get STS?
Old Jul 19, 2005 | 04:17 PM
  #121
KALEL's Avatar
Originally Posted by Zombie
People refer to lag in 2 ways unfortunately. The true definition is the time it takes to see positive manifold pressure.
Most people consider it the time until you reach full boost. Lag will vary depending on many many things, load and turbo size being the main two. Temp affects it as well. It takes me 300 rpms longer to reach full boost now that the temps here are 110+
I thought part of the reason turbo's were mounted as close to the engine as possible was to reduce lag, and that this reduction in lag was due to increased velocity and higher pressure(caused from higher heat). What I'm asking is what is it about higher ambient temps that causes increase in lag?
Old Jul 19, 2005 | 04:24 PM
  #122
bradyb's Avatar
Wow what a thread! If anyone cares I love my daily 90 mile commuter 02 STS SS. (Mattism78, I sent you a special PM/email.)
By the way, in first gear my car hits boost at 3,000 RPM. I have a lower rev-limiter programmed into my car so with the clutch pushed in I can bounce off 3500 RPM when I'm staged at the line. Give me 3 seconds and I'll have 5 PSI ready to go waiting for the light to turn. Dropping the clutch at 3,000 with 5 PSI is a pretty good way to reduce your 60'times by the way. No, I don't have good track times, the density altitude today in Salt Lake is about 10,000'
Old Jul 19, 2005 | 04:36 PM
  #123
Zombie's Avatar
The exhaust gas being hot will cause it to have extra volume. This extra volume then has to fit through the same size hole. When it all can't fit through pressure builds up in the manifold. The sooner you cause this action to happen, the sooner you will see boost.
With the turbo at the back the gas is cooler, hence less volume, but still the same quantity of exhaust molecules, they just aren't as excited as when they came out of the combustion chamber. The solution to this is to use a smaller hole that causes them to build pressure faster.
The hole i'm talking about is the a/r of the turbine housing and the wheel selection.
When it's hotter out the car doesn't make as much power, less power = less exhaust to get the boost building process going. I'm at 2200' and have excruciating day time temps. On a day like today 117 F i'm losing around 70-80 rwhp compared to a 65 F day. When I dynoed my car it was 96 degrees in the shop, my corrected numbers were 507, my uncorrected were 460.
P.S. The turbo does work better when it's up front, but it works pretty good out back too.
Old Jul 19, 2005 | 06:54 PM
  #124
PurEvl's Avatar
Originally Posted by V6 Bird
How many times do I need to tell you that ive witnessed these cars first hand that 60 ft those ETs dead hooking with turbo lag all the way to 250ft out!!!!! I cant help it if you cant ingest it. Take your finger out of your *** and listen. One was a stock 6 speed car and the other was a built 408 AUTO car. He ended up running a decent time down track but didnt boost until well after 60 ft after the 60 ft marker! 3450 isnt gutted...stock carpet, panels, etc. rear seats are removed and alot of lightweight suspension stuff.
come on admit it, that was pretty funny
oh i remember the 408 you were talking about..it had stock ******* heads...please stop before i bitch slap your *** once again. Remember my graph ..peaked at 4k on the dyno an even sooner on the street ya i thought so.
As for me being a keyboard commando..please come meet me...it will be the greatest day of your life. I wait with baited breath you sexy pillsbury muffin.
Old Jul 19, 2005 | 06:58 PM
  #125
CONVERTED's Avatar
Originally Posted by Mattism78
I thank you sir for my new sig quote...
when it's true it's true.
  #126
trtturbo's Avatar
Water issues will be taken care of shortly. STS is coming out with a filter and shield combo to once and for all remedy the chance of a problem.
Old Jul 19, 2005 | 07:03 PM
  #127
PurEvl's Avatar
bwaaaahahahahahahahah.....**** waffle assgrape?!?!?!?! That is by far the funniest thing I may have ever heard. When I went to login I started typing that in the login bank.
On a more serious note, Purevl your numbers are impressive. I haven't seen that many on an STS with those numbers, but I have only been doing some research on the kit for a short amount of time. What exactly does your setup consist of? I have considered maybe purchasing this kit in the future, but I don't plan on stopping at 500rwhp and I need to have a good plan before I start throwing money everywhere. It would also give me hp #s and expenses for this kit to compare to other setups.
Do **** waffles come with syrup?
it was
forged ls6
patriot 6.0l heads
226 cam
sts gt70 with fmic
ati damper
hooker headers
big expensive fuel system..(dont feel like typing it all out)
motron 60's
ls6 intake
ported tb
stock maf
evans waterpump
and the most important part don kinder tuning (slowhawk)
im sure if you search my name you will find the full list somewhere but thats pretty close.
Old Jul 19, 2005 | 07:12 PM
  #128
CONVERTED's Avatar
ok now that i've asked and have recieved there are actual answers to why STS are having "shitty" 60's The answer... big turbo...... not enough "excited" molecules (gas) moving into the turbo housing at a high enough volume. There for "spool" times are increased there by reducing the amount of boost avil. during your initial 225 ft or whatever you quoted. Now for the noob to school you... bigger turbo = the the opportunity to produce the greatest power How ever the bigger the turbo the more "lag" you produce...(doesn't work exactly like that but i'll assume your not a complete tard)... So your "buddy" with the STS who has a shitty 60' needs to consider a couple of things.... "brake boosting" or small turbo.. by shrinking it will reduce the amount of gas required to turn it there by reducing lag time.. so for those who have full boost or most of there boost at 3k or 3.2k they are obviously more intellengent that your buddy or your buddy was aiming for something else....
2 all of those more intellegent than myself and V6 please feel free to gently correct me... again i'm a supernoob but it appears i'm not alone.
Old Jul 19, 2005 | 07:23 PM
  #129
PurEvl's Avatar
autos (like the 2 10sec gtos) build boost on the line just like any other turbos...they 60 in the 1.4 1.5 range and at 4000 pounds thats awesome. As for the 6 speeds...any turbo will suck without a two step. V6bird just feels like leaving that out.If a stock car with 300rwhp can 60 1.8 wtf would an sts slow it down? Makes ZERO sense. Like i said hes a dickdolphin
Old Jul 19, 2005 | 07:29 PM
  #130
Mattism78's Avatar
So what's the best stall for us A4 guys to go with to make boost out of the hole?
Best not so much as in brand, but stall speed, and STR?
Old Jul 19, 2005 | 08:28 PM
  #131
Race-Prep's Avatar
Suspended Sponsor
V6, Please let me formally invite you to visit our track out here in SOCAL, I feel the need to make someone feel a little STUPID. I Have not even had the opportunity to dial my car in but I can tell you I have no fear of your supposed vehicle, I stand behind my work and I am confident that my STOCK LONGBLOCK will teach you a lesson! I simply need about a month to get my trans installed....If I loose to you I will pay for your round trip to sunny and HOT California...In other words leave this thread alone and stop badgering the members here until you PROVE your slower than an STS car!!
-Bryan
Old Jul 19, 2005 | 09:19 PM
  #132
V6 Bird's Avatar
How come I can Drive my friends singled RX7 to 1.58's to 1.62 on Nittos...We dont have a 2-step or nitrous on it..??
Old Jul 19, 2005 | 09:21 PM
  #133
V6 Bird's Avatar
-Bryan
1 month??? My car may be sold in the next week!!! If had my fun with it, school is numero uno right now...Ill build another car and this one will be a thumper framed single...no rear mount non sense.
Old Jul 19, 2005 | 09:24 PM
  #134
V6 Bird's Avatar
The only change that you could make that would matter would be larger N2O jets Other than that you WILL run slower by quite a bit. I think the only slower track than us is bandemier, but I could be wrong. Our DA is almost always above 4500 and i've seen as high as 7500 a few times. I don't even go to the track that often and I know twice i've seen 7000+ DA
Whats funny is that I can run the same ET at 1000 ft DA as I do at 4500 DA....why is that guys? It cant be....i did it the last 2 seasons
Old Jul 19, 2005 | 09:54 PM
  #135
PurEvl's Avatar
cause you can drive..asshammer
Old Jul 19, 2005 | 09:57 PM
  #136
ddnspider's Avatar
V6 bird please STFU and stop wasting bandwidth...I now officially think that some people should have to take a test just to be allowed on this site
Old Jul 19, 2005 | 09:58 PM
  #137
frcefed98's Avatar
Come on guys admit it, the STS works reasonably well for its funny placement. The results both on the dyno and those who have provided track times and vids of the STS on various vehicles show that its a nice kit to make some great power. We are talking street cars, not 200mph outlaw cars. 700rw on a street car is very impressive no matter if its Turbo, SC or N2O or NA....it'll definately get you to the grocery store quicker than stock
Mike you rock, asshammer, twatwaffle...classics buddy classics.
J
Old Jul 19, 2005 | 10:39 PM
  #138
anarchy99's Avatar
"How come I can Drive my friends singled RX7 to 1.58's to 1.62 on Nittos...We dont have a 2-step or nitrous on it..??"
you don't have to lie to sound popular v6 bird... you don't have any friends.
Old Jul 20, 2005 | 04:15 AM
  #139
NA$TY-TA's Avatar
Mike you made my ******* day buddy......... i hadnt read this thread at all yet and i read it all at once..... you are one funny ****** F^&Ker... LOL
I could have so many sig quotes from what you have posted....... I bet Don does alot of the work because you guys hang out and get drunk and laugh so much......... I say keep it going i was almost crying from laughing so hard.......
My .02 for a DD car that doesnt want to spend to much $$$ and be happy with your new found power STS is a good way to go......... its alot cheaper..... i can tell ya that much ha ah LOL :jest;
Kyle
Old Jul 20, 2005 | 04:30 AM
  #140
regorih383's Avatar
fire time
