how much power on a procharged stock heads/block ls1??
I was thinking instead of doing a cam setup to save up some more money and do a procharger on my 2000 SS... as of next week it will have jet hot LT's and ORY, borla and already has all the other little bolt-ons (MAF, lid, etc) how much power will I be putting to the wheels with a stock heads and stock cam?? what a about a small blower cam?? and which to get P1SC or D1SC? (probably will buy one used to save money)..........thanks
are there any turbo setups that I could install myself?? they seem too difficult to install (NO STS systems, I don't want everyone to know that it is boosted) oh and this is a daily driver.........
me and a few friends of mine installed my p1sc and it came out good, havin a problem with the tune but i should be up at 500 hp although you will hear a whistle at low rpm
Stock block, heads and Cam. LS6 intake. 42 lb injectors. Walbro Intank.
1.85 rockers and LS6 springs are the only motor part changes.
Jet Hot long tubes, custom y-pipe, 4 inch to a turndown
D1SC with a 3.4 inch pulley (about 10 lbs)
Water/alcohol injection (for insurance)
508 HP on my own safe tune! (LS1 edit)
See sig for track times!
If you go Supercharged, get the SDCE kit with 8 rib spring loaded tensioner!
Procharger D1sc
Is the only way to go. Just finished mine, and it is great!!! Putting down 540hp 533tq on a stock block exception of 1.85 rocker arms. It to is a daily driver. No Problems whats so ever. Go with the D1 over the P1 will give you room to grow for future mods. Make sure you go with 8 rib upgrade! And there will be no belt slippage issues. And a good tune is a must.
Chris
Chris
