new blower pulley and new numbers
Gomer is running the numbers and I'm sure he'll jump in and explain where we are at.
John
Also, what does everyone think is the maximum rwhp attainable with a racetronix PnP fuel pump assuming you have the supporting injectors? Do you think adding the 1:1 rise regulator to his system will cure the problem up top? The injectors were running 20ms at 6500rpm on that run.
btw.. I only have 19* of timing in it up there where it goes lean. It didn't get any knock retard last night on the dyno and it was hella hot and humid in there. I'm not worried about him hurting it right now, but I want to fix this problem before he does the exhaust upgrade, I know it will make a good bit more power then.
