New D1sc What Kind Of Numbers To Expect
I've Just Ordered A D1sc 8PSI And 42lbs Injectors Diablo Tuner And Spec Stage 3 Clutch Does Any One Know What Kind Of Numbers To Expect I've Heard 450 To 550 . ALL THIS IS FOR A 2000 LS1 CAMARO.
I Have Mac Mid Length Headers And Y-pipe And Borla Cat-back Installed
I Also Have Hooker Long Tube Headers And Y-pipe In My Garage Maybe I Should Install Those Instead . Thanks For The Help
The hookers w/ a 3in ory would be better or a 3in x-pipe w/ turndowns and bullets. you should also get a ported TB and LS6 intake
UR injectors should be good for up to 550rwhp. Also if ur running on the stock bottom end dont go over 8psi w/o meth or alky injection
A 12-bolt would be a good idea as well.
Originally Posted by bob19
I Was Going To Get It Dyno TuNed But I Thought That Is What They Used. YOUR MAC STUFF SEEMS TO BE WORKING GREAT
Mac mids are good, used to have em on my SS when i had a heads/cam setup and i still made good numbers but since you have the hooker headers/y-pipe why not just put em on. Im sure they'll be worth a lil more power over the macs
