Procharger Psi HELP ORDERED WRONG PULLEY
Old Aug 2, 2005 | 08:05 PM
bob19's Avatar
Default Procharger PULLEY QUESTION
I Need To Know How Much Psi A 3.43 Inch Pulley For A D-1sc Will Produce?
Old Aug 2, 2005 | 09:17 PM
Ferocity02's Avatar
I'm guessing 8#
Old Aug 2, 2005 | 09:18 PM
Grasshopper's Avatar
Tell us a little more about your engine. Stock compression ratio? Stock pistons and rods? Heads? 6 rib drive system or 8 rib?
If it's all stock, an 8 rib 3.4 pulley with a D1SC is going to destroy your engine in a day or less!
LSs1Power's Avatar
I think 9-10psi because i got sent 3.6 pulley for 8psi on a cammed/full exhaust car which will read 1-2psi lower than your setup.
Old Aug 2, 2005 | 09:21 PM
With what? A P1SC?
Old Aug 2, 2005 | 10:44 PM
LSs1Power's Avatar
Originally Posted by Grasshopper
With what? A P1SC?
D-1SC with the 6 rib ATI crank pulley. They sent it to me by mistake because i ordered an 8 Rib setup from them.
Old Aug 2, 2005 | 11:11 PM
bob19's Avatar
Its All Stock And And It Is A 8rib Im Getting The 8psi Pulley With The Kit . Sense It Was Taking So Long They Through In A Smaller Pulley They Gave Me To Choices 3.7 And 3.4 Now I Think I Won't Be Able To Use It.
Old Aug 2, 2005 | 11:13 PM
LSs1Power's Avatar
If its the 8 rib ATI setup then the pulley size you posted will see 14psi or so. Im running a 4.25 pulley seeing 7.5-8psi now with the stock 8 rib ATI crank pulley which is 7.65". Check the crank pulley size before you run that small 8 rib sc pulley.
Old Aug 2, 2005 | 11:23 PM
bob19's Avatar
Ok Thanks
Old Aug 2, 2005 | 11:40 PM
Ferocity02's Avatar
My 3.6 pulley doens't even hit 5psi, maybe 4.75psi.
Old Aug 3, 2005 | 08:56 AM
That's more like what I was thinking. A stock engine isn't going to last long on 14psi.
Old Aug 3, 2005 | 09:56 AM
WHPLASH's Avatar
My 3.2 hits 8-9lbs on a 6 rib
Old Aug 3, 2005 | 11:51 AM
6 rib --- 8 rib
Apples -- Oranges
Old Aug 3, 2005 | 01:54 PM
LSs1Power's Avatar
The difference between the 6 rib and 8 rib ATI is the crank pulley size. The 8 rib has a larger dia size crank pulley which will increase boost. That is why running the same blower pulley size from a 6 rib on an 8 rib kit will give u more boost.
For example, 7-8psi on a 6 rib for my car was giving with a 3.60 SC pulley and the small 6 rib crank pulley.
7-8psi on the 8 rib was giving with a 4.25 pulley and the larger crank pulley which is 7.65".
I hope this explains the difference.
Old Aug 3, 2005 | 02:29 PM
BudH's Avatar
I'm running a 6 rib 3.4 inch S/C pulley with a stock ATI crank pulley!
10 lbs of boost @ 6300 rpm
Jet Hot Long Tubes
3 inch mandrell bent Y-Pipe to a 4 inch pipe with bullet muffler and a turndown
1.85 SLP rockers and LS6 valvesprings
LS6 intake
Everything else stock!
508 RWHP unlocked
Times in the sig!
