RWHP on stock crank?
Old Aug 3, 2005 | 08:56 PM
JESTERSS's Avatar
Default RWHP on stock crank?
How much RWHP/ RWTQ can a stock 02 (if that matters) crank withstand safely?
Old Aug 3, 2005 | 09:05 PM
White_Hawk's Avatar
Harlan had to be at least 1000/1000 when he ran his 8.29 at Thunder last year. I am not saying that is a good idea though...
-Geoff
Old Aug 3, 2005 | 09:12 PM
goober35's Avatar
do you want max or do you me DD max and at what RPM
Old Aug 3, 2005 | 09:23 PM
JESTERSS's Avatar
around 6500 rpm. I dont know what is meant by max or DD max. I want to just get forged pistons and rods, on my daily driven procharged SS and get the most boost/hp I can while still being safe. This is a daily driver so take into consideration I will be driving it almost every day. I REALLY dont want to break anything unless it is absolutely necissary.
Old Aug 3, 2005 | 09:29 PM
goober35's Avatar
daily driven=DD
How much power do you want.
Old Aug 3, 2005 | 09:32 PM
JESTERSS's Avatar
I want around 650, but if a stock crank can only withstand 600 ill settle for that.
Old Aug 3, 2005 | 09:35 PM
NoGo's Avatar
I think the stock crank is pretty stout.
Nitrated stock crank on the below numbers. The motor has 10k street/strip miles on it already.
Old Aug 3, 2005 | 09:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm on a stock crank just polished.
Old Aug 3, 2005 | 10:06 PM
MIGHTYMOUSE's Avatar
stock crank here, but iron block, daily driver
Old Aug 3, 2005 | 10:17 PM
Armageddon's Avatar
...with cheese.
stock cranks are stout, don't worry about it
Old Aug 3, 2005 | 10:42 PM
goober35's Avatar
Iron block with a fully studded block and a stock crank polished. I am going for 600-650rwhp. Should be very do able. Just got to keep the air cool
Old Aug 4, 2005 | 09:59 AM
InconFormula's Avatar
650 rwhp is just getting that thing warmed up!!!
Old Aug 5, 2005 | 12:42 AM
Wicked_Hugger99's Avatar
same here
Old Aug 5, 2005 | 06:56 AM
KraZy's Avatar
I agree with the above posts.
Old Aug 5, 2005 | 07:03 AM
ProjecT 9's Avatar
what does polishing a stock crank do? im assuming make it stronger, but do you mean just having it shined up?
Jon
Old Aug 5, 2005 | 10:10 AM
Race-Prep's Avatar
Suspended Sponsor
Usually, they mean the journals. Polishing preps the surface for good bearing life, I would asume that is what they mean. I can't see polishing the whole crank to be necessary. I would like to know how many people are running or have run 1000WHP or very close on the stocker, and for how long...
-Bryan
Old Aug 5, 2005 | 11:04 AM
ProjecT 9's Avatar
-Bryan
me too...so if the stock crank is that strong, what is the purpose of getting a forged bottom end? why not just get forged rods and pistons...i was gonna get a forged bottom end soon, but if that isnt neccesary then ill just get the crank polished...anyone mind chiming in and educating me? thanks
Jon
Old Aug 5, 2005 | 12:10 PM
FastKat's Avatar
That was also my plan... from what I've seen the stock crank is a pretty strong piece, much stronger than previous GM smallblock V8 cast cranks.
Jon
Old Aug 5, 2005 | 01:13 PM
DarkHorse's Avatar
How about the stock LT1 cranks - you guys have any ideas? Will I be safe with forged rods and pistons running about 8psi off of an SQ S-Trim?
