touch screen boost controller
Old Aug 7, 2005 | 08:59 PM
zoxygen's Avatar
Default touch screen boost controller
Is there a way to put a boost controller on my indash flip out touch screen?
Anyone know of anyone who has done this or if its even possible??
Old Aug 7, 2005 | 09:52 PM
TchargedLS1TA's Avatar
Yea, hunt down the design crew of the fast and the furious...
Its possible, but you would need to find someone with some serious programming abilities..
Old Aug 7, 2005 | 11:18 PM
Armageddon's Avatar
...with cheese.
damnit! you beat me to it
Old Aug 7, 2005 | 11:44 PM
NOIR's Avatar
cool idea tho . the eboost controller i found costs 500 anyway. lol so since the hardwre is already there it may not be too bad.
Old Aug 8, 2005 | 07:14 AM
Brains's Avatar
Warning! you just blew the welds on your intake manifold!
Old Aug 8, 2005 | 08:19 AM
Reject's Avatar
Yeah that happen'd more than twice now!
Old Aug 8, 2005 | 01:01 PM
I dunno bout you guys, but my diamond plate floorboard fell off doing a 9 second, tire spinnin wheel stand..
Old Aug 8, 2005 | 02:30 PM
Reject's Avatar
did you use "NOS, two of them" to make the diamond plated floorboard fall off?
Old Aug 8, 2005 | 02:31 PM
sb427f-car's Avatar
SSU'S Vice Mod
What? Next thing you know he'll be injecting propane and N2O on top of 136#s of boost Oh wait a minute, they do that in the diesel world
Old Aug 8, 2005 | 02:36 PM
Reject's Avatar
"Got enough NAWS to blow himself up!"
Old Aug 8, 2005 | 04:11 PM
SporkLover's Avatar
your best bet is to take a profec, and try and rig up some kind of flip screen motor setup.... but then you wont really be adding it to your current touch screen....
http://store.yahoo.com/nonturbo/gred...ontroller.html
Old Aug 8, 2005 | 04:23 PM
eviltwins's Avatar
You can run a computer inside your car, hook that up to an AEM EMS, and hook the output up to your DVD player, then use your DVD player to control boost, nitrous, datalog, tune, etc, etc.
Old Aug 8, 2005 | 08:01 PM
Eh, propane is for pussies.. Im pushin 600 hp to the wheels with only 48 psi of boost.. All on #2 diesel baby...
And i only used one big 75lbs bottle.. Two bottles would have been to conspicuos on that very well lit illegal drag strip in the middle of LA.. Woulda scared too many of my g-force mac daddy mexican homies away with that amount of power. NAWS is a dangerous thing man- you only live your life a quarter mile at a time, you dont wanna screw that up..
Old Aug 8, 2005 | 09:32 PM
sb427f-car's Avatar
SSU'S Vice Mod
lol! PM me your setup! I'm seriously thinking there will be a diesel sport truck in my future, and not a full sized one either
Old Aug 8, 2005 | 10:59 PM
Frost's Avatar
You guys joke but this got me thinking
I am a controls engineer and this type of interface is a small part of what I do... I had some salesmen bring lunch and a presentation recently that included some very small color tft touch screens (HMIs) WITH imbedded I/O. There are scaled mixed dig/analog models available as well in as small as 4" and in 2" increments right on up to large-by-huge. With a DC2DC converter, their 24V supply is covered. These things were fairly cheap too (as far as automation hardware goes) and included the logic and interface developement environment. I want to say that the smallest models were available for around $500. There are quite a few things you could do with this, especiallly with the available I/O... It could completely control and monitor a nitrous setup for example as well as the aforementioned application. If I can find enough justification for it I'm going to look into it myself. This type of prgramming, even the logic side is very high-level, it will be very easy for anyone who does this kind of thing to hit the ground running.
There have to be some other controls guys or general EEs around this site, right?
Old Aug 8, 2005 | 11:12 PM
Frost's Avatar
As a matter of fact.... just doing a quickie I found this controller and analog expansion module that could add a TON of control options .... monitor A/F in real time (with wideband o2), turn on your meth at a certain psi, etc and 3 other analog sources like TPS for instance.... (nitrous ON at @....) control the on(s) and off(s) of literally anything you wanted....
Cheap back-end controller:
http://web2.automationdirect.com/adc..._Units/D0-05DD
Analog module:
http://web2.automationdirect.com/adc...ules/F0-04AD-2
Although as I said, the stuff I was shown at work was much more affordable than automation direct...
Old Aug 8, 2005 | 11:18 PM
longrange4u's Avatar
LMAO... did it blow through your floor panel???
Old Aug 9, 2005 | 12:21 AM
V8_DSM_V8again's Avatar
Ha Ha
The fastest DSM uses a Hallman manual boost controller.....
I use a DIY manual I saw in plans on autospeed.com that the author uses on a skyline...
I also use a simple procomp liquid filled mechanical boost gauge.. No indeglow or other nonsense. No huge wing. No fart can......
Old Aug 9, 2005 | 07:12 AM
Lasershop's Avatar
Most of these guys have siphoned way too much gas. Sounds like you know your stuff.
Old Aug 9, 2005 | 08:16 AM
MTBDOC's Avatar
As I put my LS2GTO together, I have ordered a wideband commander, looking at boost gauges; need computer tuning; working on the stereo....
...which has led me to believe we need to develop a car-pc that can do it all: monitor afr, boost, timing/kr/all other parameters from the OBDII port [like the aeroforce gauges], audio/video system, nav [if that's your cup of tea], and, of course HPTuners or similar software. Boost/methanol injection/N2O/fuel pump voltage boost/etc could all be controlled here => drive & log => retune => easy feedback/monitoring/adjustment.
So...LET'S GET WORKING ON THIS!!!
