hey STS guys
Old Aug 8, 2005 | 05:35 PM
JustAnIlluzion's Avatar
Default hey STS guys
looking back at your kits.. do u think someone could piece together one easily? We have a ton of mandrel bends here, a buddy of mine is a great welder and knows alot about turbo builds. 5psi is all i would run until id get a IC. fuel and tune would be the biggest tasks IMO.
Old Aug 8, 2005 | 06:30 PM
Zombie's Avatar
I remember those days.... 11 psi later...
Easy to make yes, just gotta find a pump that works good. I would not take on the task without some experience though.
Old Aug 8, 2005 | 06:42 PM
strykerZ28's Avatar
Zombie. I would love to see pics of your car/setup.
Old Aug 8, 2005 | 07:30 PM
EPP's Avatar
EPP
That is a very sanitary looking system. Bob
Old Aug 8, 2005 | 07:32 PM
Jammer's Avatar
heres mine
Old Aug 8, 2005 | 07:34 PM
Jammer's Avatar
Thanks Bob, I actually deleted the first post for this one as the pics in this post are abit clearer, I'll add a few more from the build process.
Old Aug 8, 2005 | 07:40 PM
Jammer's Avatar
more...
Old Aug 8, 2005 | 07:54 PM
69firebird's Avatar
jammer,
that is an awsome setup you have. if you could do it all over again woudl you do the CAS or the STS that you have?
Old Aug 8, 2005 | 08:17 PM
94formulabird's Avatar
I had mine custom built with stainless steel..Just ran the pipes next to the subframes..that way I can have subframe connectors....with the STS kit you cannot have subframe connectors.
Old Aug 8, 2005 | 10:46 PM
Jammer's Avatar
I have my FC's too.
69 Bird, I like both...the CAS is a pain in the *** to work around an install but made ripping power, but had some creep due to design
The rears are easy to work on and create alot, and I mean alot, od parking lot talk and peopel on their knees. I wish more chicks came out to the "lot" on those late nights out. The power seems excellent, but Im awaiting a final tune.. I can tell you I make about 475-500 ftlbs tq at just over 4200 rpm at 7.5 lbs boost... then she runs into some tuning issues (car is sitting on dyno tonight).
I change every year, problem is I get too busy to complete it till Late Aggust each year and never have much road time here in NY.
I will sell this kit and pick another for next year.
Old Aug 9, 2005 | 01:12 PM
jammer great setup
Old Aug 9, 2005 | 01:40 PM
marcus769's Avatar
Jammer, WOW....................................... That is soooooooooooo awesome........
How much power do you have?
Where was all this work done?!
Any idea on $ value of setup?
Old Aug 12, 2005 | 05:54 PM
Jammer's Avatar
Thanks guys!
Still unsure on power, have some tuning issues between 4200 and 5k rpm at WOT......checking mechanical/electrical. I can tell you it makes excellent power based on a few pulls that have been forced to the 6200k range, but were not counting anything till the tune is finalized. We havent pushed it above 8 lbs yet either....and we hoping to reach 15, which is where I began to knock on pump gas with the CAS set up .
We did all the work here, between friends (Redline and Master-Kraft). I did the basic design, Master-Kraft did some nice welding, and Redline Motorsports in Schenectady has a fresh dyno dynamics.
Value, No idea...I will sell it for about $4500 when the time comes. It should bolt right on most F-bodies with minor adjustment/crossover dependant.
Old Aug 13, 2005 | 12:08 AM
Lrry93's Avatar
where did you put your air filters?
Old Aug 13, 2005 | 01:02 AM
Jammer's Avatar
On the turbos...K&N cones, since I only drive on weekend nice nights I never had a concern like some did about heavy rain or puddles. Not sure if that would ever be an issue.
