Do MAP sensors go bad with turbo?
Old Aug 11, 2005 | 07:02 PM
musicmaker1586's Avatar
Default Do MAP sensors go bad with turbo?
I noticed when running HPT that the map sensor gauge read 0. I check to see if it was pluged it and everything and it is. Just wondering if they can go bad and what is the stock sensor (1 bar or 2 bar)? What should I get a 2 bar? Where is the cheapest place to get one?
Old Aug 12, 2005 | 12:41 PM
stevieturbo's Avatar
If you are using a stock 1 bar map sensor. It will not read any postive pressure at all, so would max out at "0"
1 bar = 0psi.
2 bar = 14.7psi
0 bar would refer to vacuum, which is all a normally aspirated engine needs to see.
Old Aug 12, 2005 | 06:05 PM
I understand that but what is the stock map sensor 1 or 2 bar?
Old Aug 12, 2005 | 06:24 PM
1 bar.
Old Aug 13, 2005 | 06:15 AM
anybody else?
Old Aug 13, 2005 | 09:27 AM
BW's Avatar
BW
it's a one bar sensor, can't read positive pressures as stated by stevieturbo.
Old Aug 13, 2005 | 09:43 AM
SS2win's Avatar
its a one bar and I dont think you will hurt it. if you put in a 2bar then you will have to half all the MAP related tables in your tune to compensate.
Old Aug 13, 2005 | 02:53 PM
Boostaholic's Avatar
All the 1-bar sensors I have tested read vacc and +1.2psi
Old Aug 13, 2005 | 03:40 PM
whynot's Avatar
same here, I have always heard that the 1 bar map sensors will read slight boost, not much at all though.
Old Aug 13, 2005 | 06:27 PM
tici's Avatar
I see max 105 kPa = 1.05 bar
