ATI Procharger @ 8 lbs.
Also, with a proper tune will 8 lbs. harm the LS1 in the long run? Thank you so much.
I can give u a better estimate next time i run the car with the new clutch. Most likely im going to use ET streets this time around.
replied to your PM
Kyle
With proper tuning and with the air/fuel ratio in the 11.7 to 12.0 range at wide open throttle, and with 42 lb fuel injectors and a higher capacity in tank fuel pump, you will end up with a very durable and dependable combination that still gets good gas mileage. Driveability with these combinations is excellent!
We just installed and tuned a one owner '94 Corvette LT1 car this week that we installed an ATI ProCharger D-1SC on. Amazingly this Corvette has 192,000 miles on the internally untouched original engine! The owner realizes that he is putting the cart before the horse with adding the ProCharger, but said he'll just have us rebuild the engine if it goes... Bob
If I'm already at almost 350 rwhp, can I expect to be around 480-490 rwhp? And is this with a tune or without a tune?
Thanks,
Phil
Thanks,
Phil
the problem is from what I understand that you can only go so far on the stock heads/cam before detonation and knock start coming into play.
if you upgrade aftercoolers im sure that would be no problem, but EPP is right, average is anywhere from 430-460 possibly rwhp on stock motor with minor bolt ons.
Thanks,
Phil
I'm assuming your numbers were achieved on a DynoJet, which does not apply a load against the cars drivetrain like a Mustang Chassis Dyno does. On a DynoJet chassis dyno you would indeed be up in the 480 to 490 rwhp range.
These numbers certainly are with a tune. You would never want to go wide open after adding a supercharger without some sort of tune! The fuel ratio needs to be richened up to keep the pistons from self destructing. Even one or two wide open runs without a tune can be potentially fatal to the engines longetivity. A mail order tune is better than no tune at all, but does not compare to getting a tune done on a eddy current chassis dyno with a wide ban air/fuel ratio meter. Bob
Bob...when did they start making Eddy Current dyno's? Can it scan for cracks in rims too <NDI/Eddy Current joke>
