Poll: Heads/Cam or Supercharger
Thx
get heads, cam, and 12 bolt. probably still wouldnt spend what you would on a charger,install, and tune.
for h/c i'd go AFR 205's, cam of choice, Fast 90/NW, fuel system (injectors/pump), and your current bot ons.
another option is cubic displacement, you can get a 402 and h/c for the price of a P1/D1. or you can look into the STS as well. there's a plethora of options, find the one that best suites your budget and application.
also, with either n/a or FI the little **** add up faster then you think..
blower cars with a stock bottem end aint maken alot more power then stock bottem end H/C cars...
FI is $$$$ lots of it... yes it can get you rediculouse hp...IF you have 5500 to sink into a shortblock 5500 to sink into the charger and pluming, 2500 to sink into labor, 800-1000 for tuning, 500-1000 for fueling .....
then you get the honor of spending at LEAST that much more to build the rest of your car to HANDLE that power...
but, it depends on your "ULTIMATE" goals. you can realistically get similar power out of both H/C and FI on a stock bottom end.
if you like the lope, go H/C, if you like the whine/better daily drivability, id go FI.
jaberwaki is right > a good set of heads and cam will make the same hp as a stock bottom end and blower. (maybe a few hp here or there) Both ways are not cheap > that is unless you get cheap stuff.
lets play devils advocate and say they do, you gotta sacrifice a ton down low to make it up top plus have a shitty idle.
stock bottom end fi cars have gone as high as high 500's/low 600's at the wheels.
