View Poll Results: H/C or FI
H/C
31
34.83%
FI
58
65.17%
Voters: 89. You may not vote on this poll
Poll: Heads/Cam or Supercharger
Old Aug 20, 2005 | 03:22 PM
Reject's Avatar
i know there is a thread that says something about the gas miliage with a turbo, that you get tiny bit better gas mileage becuase of better efficiancy, something like that?
so woundnt a head cam car be less gas milaege?
Old Aug 20, 2005 | 03:29 PM
ddnspider's Avatar
and 450-500rwhp is 450-500rwhp so either way you have to do the other mods to the driveline motor etc.
Old Aug 20, 2005 | 03:57 PM
30th t/a's Avatar
Originally Posted by Got Me SOM
o ok so the NORM for heads and cars are 450-500 plus horsepower at the wheels? I dont think so.
lets play devils advocate and say they do, you gotta sacrifice a ton down low to make it up top plus have a shitty idle.
stock bottom end fi cars have gone as high as high 500's/low 600's at the wheels.
you dont need a ton of torque when you have 4:10s. the gears will make up for the loss of torque. my buddy with a torquey 2.8 pullied cobra found out the hard way. 4:10s are aweesome with a 6 speed, you can actually use 6th gear.
"shitty idle" thats your opinion..some like me, love the thumpin idle while some dont. im gonna miss the pounding idle of the H/C setup.
with a GOOD H/C setup....meaning all the boltons, good heads like afr 205s nice sized cam and the 90mm lsx setup and 6 speed car should easliy see 450rwhp.
its been said a trillion times before, dont get caught up in PEAK numbers. compare the dyno graphs of a stock bottom end 8 psi supercharged car to a well setup stock bottom end H/C car.....who has the better curve?
Old Aug 20, 2005 | 04:04 PM
30th t/a's Avatar
ill say this, it is alot easier to get into the 10s with a turbo or supercharger and still have a full weight, stock wheels, nice driving car but you will need a forged bottom end to play it safe because you'll need more that 8psi ( yea yea i know some people are brave and are doing it on a stock bottom end). with a maxed out 346 H/C setup running stock 17" w/ slicks in the rear, full weight, bottom 11's will be hard to be. if you want any faster your gonna be stripping some weight off the car.
Old Aug 20, 2005 | 04:12 PM
Got Me SOM's Avatar
"its been said a trillion times before, dont get caught up in PEAK numbers. compare the dyno graphs of a stock bottom end 8 psi supercharged car to a well setup stock bottom end H/C car.....who has the better curve?"
the forced induction car and your point was ?
and you don't need gears to help the motor stay high in the revs with fi-yet another bonus.
this is apples to oranges.
Old Aug 20, 2005 | 06:13 PM
2000silverbullet's Avatar
Everyone has an opinion about how to make HP/TQ and good track numbers > bottom line is, if you run more than 8psi on a stock bottom end and don't spend the $$ for a good fuel system >
I have a blower set-up with nothing stock (internally) and prior to that I didn't and ran 10psi for about 10 seconds and
Either way you do it > don't look for short cuts
Old Aug 21, 2005 | 10:25 AM
BOONE's Avatar
Ive had 3 blower cars with stock bottom with 10 to 13 lbs of boost and drove the last 2 past 100000 miles like that, and i was mean to them every chance i got. This one tunes as in my sig on a mustang dyno, and now has a bit more power than then. Im cruel to it every day. If it has knock it will break, if it dont it wont, period. I sprayed them all with meth or meth and water. Only problems ive ever had was with overreving and bent valves, and that is the only thing ive ever tore into one for, till they lose compression and need rebuilt. Ive had head and cam cars for 20 yrs before that and its much more thrilling to drive FI. I like lope and whine he he. Detonation is what breaks stuff up, it just dont work even with a slight amount, so go overkill if you have to to combat it, its better than being unreliable. Remember Robs Turbo car. Controversial or not it was durable under extreem boost, as it was done safely. I will go forged soon as i need to this time, but not untill it breaks or wears out as im not selling this one. Forged is the best undeniably but stock pistons will hold high hp for tens of thousands of miles if not getting knock. If yours broke its from detonation.
Old Aug 21, 2005 | 03:31 PM
Jeremiah's Avatar
Originally Posted by jaberwaki
blower cars with a stock bottem end aint maken alot more power then stock bottem end H/C cars...
My car made 508 rwhp with the stock bottom end on 93 pump gas with the Procharger kit and exhaust only. With forged pistons "stock comp", upgrading the fuel system and a blower cam it made 570rwhp with only 10# boost. Also as long as you stay out of the boost it still does fine on gas millage. Drivability is great, It idles and drives like a near stock car with a stall and hexhaust and ice cold AC.
Show me a H/C car that still has exellent street maners, no drivability issues and is making well over 600HP at the crank.
Old Aug 21, 2005 | 03:36 PM
blkZ28spt's Avatar
I choose high compression heads/cam to make 450-480 rwhp then forge the bottom end, upgrade the fuel system and spray it.
No, not really. With proper suspension, minimal weight reduction, rear end with proper gears, clutch/converter (in other words supporting mods any car needs) bottom 11's or better with heads/cam is fully obtainable.
Old Aug 21, 2005 | 03:59 PM
00RedWs6's Avatar
my good friend here is running 11.20s CAM ONLY A4 with minimal weight reduction. Another friend in his 98 TA ran 10.93 with a small cam by todays standard and 150 shot. Take it for what its worth. Decide on your own which way you want to go because there is just about an even split on which way people on here would go. Do what YOU want and enjoy it.
Old Aug 21, 2005 | 05:49 PM
30th t/a's Avatar
well i was talking 0 weight reduction and running 17" wheels w/ 17" slicks on the rear. if you know of anybody on here running 10s in a full street setup, 346cid im very interested in seeing what they got. ive done a ton of research and off the top of my head cant remember if i ever found anybody. i know some people got in the 11.2's. no -3000da either
Old Aug 21, 2005 | 05:52 PM
  #32
blkZ28spt's Avatar
Why would you buy 17" wheels to put slicks on? You don't put slicks on your stock wheels because they aren't a daily type tire.
Guess I'll do some searching in the 10/11 second forums later.
I personally know one person running 11.2's cam only. Why are you stipulating such a strct "full street setup"?
Old Aug 21, 2005 | 05:53 PM
  #33
30th t/a's Avatar
with all the cars on here, isnt there anybody with a 346 with a top of the line H/C/lsx90mm setup that would line'em up with a 346 8psi supercharged car? thats a race i never saw and im still waiting to see.
Old Aug 21, 2005 | 06:00 PM
  #34
30th t/a's Avatar
"who has the better curve" my point was .....who has the better curve...that was a question...meaning, i was curious to know who has the better power curve
and you dont need boost to melt the pistons in your stock bottomend car with H/C car - yet another bonus.
Old Aug 22, 2005 | 10:57 AM
  #35
300bhp/ton's Avatar
reckon thats a 'question mark' there, NOT an 'explanation mark'. Meaning it was probably a question not a statement. (I know the English language can be real difficult at times......).
As for low down grunt, well obviously an FI car should produce more. BUT as a centrifugal blower is rpm dependant, it may not be by much, also if it takes until 2000rpm (this is hypothectically speaking) before any significant boost is acheived then n/a and FI will be pretty close. If the FI unit is low CR it may well produce slightly less torque to begin with.
Gears - these will help over come any lack of low down grunt, and with a H/C it will also be beneficial in the higher rpms. If the FI car is still running a stock cam the higher rpms will not be its most preferred place.
Apples to oragnes - Don't be silly, its the same car with the same motor and both/all mods can be done to it.
If its a road car either setup can and does work well.
Apples and oranges would be comparing a sports bike to an 18 wheeler, NOT a slightly different solution to the same question regarding the same engine in the same car.
Old Aug 22, 2005 | 12:55 PM
  #36
blkZ28spt's Avatar
Here, let me help you understand this.
The first part
the forced inductin car
is making a statement to answer a previous question. The second part
is a question. It can get confusing, can't it?
Think of it the same way as if someone back in grade school said "I know you are but what am I?" See how you can have both a statement and a question in one sentence??
Old Aug 22, 2005 | 04:58 PM
  #37
300bhp/ton's Avatar
The first part is making a statement to answer a previous question. The second part is a question. It can get confusing, can't it?
its either that or you where just jumping the gun? Q.E.D.
Old Aug 22, 2005 | 05:09 PM
  #38
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i did h/c/sc hehehe
Old Aug 22, 2005 | 09:29 PM
  #39
GTOLarry's Avatar
Originally Posted by soontobeLS1
I was told by the shop that installed my parts and tuned my car that a blower is a better way to go, more power, better driveability etc. Only costs a little more. States a blower car is wayyyyyy different than a heads/cam car. Any input would be appreciated.
Thx
Blower gives you the power and stock driveability. Upside
With blower you may have new issues.... belt slippage and cost. downside
I have a Vortech on my 04 GTO which is my daily driver. Only other engine mod is the exhaust (jba's, RT's and a Bassani) and it drives no different than stock under part throttle. It was tuned Friday and it made 480/450 on a dynojet.
Old Aug 22, 2005 | 10:50 PM
  #40
30th t/a's Avatar
[QUOTE=blkZ28spt]Why would you buy 17" wheels to put slicks on? You don't put slicks on your stock wheels because they aren't a daily type tire.
I personally know one person running 11.2's cam only. I personally know one person running 11.2's cam only. Why are you stipulating such a strct "full street setup"
well i wouldnt buy 17" wheels but if my car came with them...oh wait...it did, just like all ws6's and SS's. whats wrong with running MT et streets? yea yea i know their not a true "slick" plus i dont drive my car in the rain.
im not saying there isnt any full weight, 17" wheels with et streets/DR's, 346cid, H/C, 93 octane in the 10s, but i would love to hear more about them. let me know if you find any cause i havent.
because thats what really impresses me.
